Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A6 c5 99'' 2,5TDI V6 ei lähe pöörde.
 Lehekülgi:  1  2  3  4
Pealkiri: A6 c5 99'' 2,5TDI V6 ei lähe pöörde. (Vastuseid: 80 | Vaatamisi: 17710)
postitati 13.12.11 19:39 Tsiteeri
Algselt postitas: ülks
Algselt postitas: automees6
Algselt postitas: Gemmu
Teile ka siis siia midagi arutamiseks.
00550 - Start of Injection Regulation
17-10 - Control Difference - Intermittent
Mis arvate teie.
Ette tänades
Germo.
Süüde on paigast ära.
Täpsemalt peaks vist varasem olema?!
Veakoodi põhjal ei saa öelda kuid eelmist posti silmanurgast nähes kus kiidetakse, et plahvatab ise käima siis on süüde varane. Viga võib muidugi pumbas ka olla. Ja kui õhku hirmsasti vahele kisub võib ka seda viga vahest visata.
Gemmu
Registreerunud 21.04.10
Auto: Audi A6
kuidas ma teda reguleerida saaksin? et paika asi saada?
Gemmu
Auto: Audi A6
postitati 13.12.11 19:52 Tsiteeri
08-10 - control Limit Surpassed - Intermittent vb oli see teine veakood.:(
Gemmu
Auto: Audi A6
postitati 13.12.11 19:55 Tsiteeri
Oleks hea kui leiaks mingise kokkuleppe et mis edasi teen. kisun pumba maha ja ei proovi enam midagi muud, ja vaatan mis garantiis öeldakse pumba kohta?
Kalle-
Registreerunud 05.06.08
Auto: Audi Allroad 2.5 TDI BMW 520i Nissan Sunny
postitati 14.12.11 01:13 Tsiteeri
Mis arvate teie.
Ette tänades
Germo.
See kood võis sisse jääda ka pumba peale sättimisest. Kui kustutades tagasi tuleb siis jah, süüde vale jne.
00550 - Start of Injection Regulation: Control Difference
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Loss of Power
Starting Problems
Transmission in Emergency Mode
Possible Causes
Fuel Tank incorrectly filled with Petrol or Biodiesel
Air/Water in Fuel System
Injection Timing incorrect
Electrical Fuel Pump faulty
Possible Solutions
Check Fuel Tank for Petrol and Biodiesel
Drain Tank and Fuel System
Check Fuel System for Air/Water
Check Fuel Supply and Return Lines for Blockage and Leaks
Check Electrical Fuel Pump
Check/Correct Injection Timing
Perform Basic Setting / Use TDI-Graph
Aitan diagnostikaga. VCDS 805 ja VCDS 106.
WVP
Registreerunud 31.01.10
postitati 14.12.11 15:21 Tsiteeri
keera süüdet paar kraadi varasemaks ja too pool sellest rahast, mis sa plaanisid pumba remonti eest maksta mulle.
Gemmu
Auto: Audi A6
postitati 14.12.11 15:38 Tsiteeri
Algselt postitas: WVP
ohh. kift variant. miks keegi ära ei põhjenda mulle siis seda et märgid on paigas jne.. et auto ju läheb mu väga ilusti käima, naq varemgi. aga vütan selle tegevuse homme õhtul ette ja annan teile teada kas muutus midagi või mitte, mingi lihtne variant on ka kuidas süüdet timmida ? või mingine õpetus.
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 14.12.11 15:50 Tsiteeri
No mingi teoreetiline võimalus ju tõepoolest on, et pritsehetk paigast ära, a üldiselt ei juhtu sellega midagi niimoodi äkki, et masin sõidab ilusti, üks hetk hakkab jõnksutama ja pöördesse ei lähe seepärast, et "süüde" läks paigast ära. Pigem mina loeks välja sarnasuse siin palju kirjeldatud ülerõhuprobleemidega. Soovitaks ikkagi pöörduda mõne pädeva spetsialisti poole (kasvõi konsulteerimiseks) kes nende mootoritega ka tegelenud on.
WVP
postitati 14.12.11 16:27 Tsiteeri
Mis moodi sa "märke" kontrollisid?
Gemmu
Auto: Audi A6
postitati 14.12.11 18:05 Tsiteeri
Vänt paika, Pump märgis ja ei usu et nukkasid ära tõmbas, . oeh. ei hakkagi end hellitama, vaid homme õhtul võtan siiski pumba maha, reedel läheb garantiisse ja jään ootama mis nende poolt mulle öeldakse. siin ju ei ole keegi sellise probleemiga tegelenud, ütlete muudkui mulle et süüde paigast ära.
Samas keegi ei oska õpetada kuidas saaksin seda kontrollida, siis viin pumba kontrolli ja kui korras, viin Revalisse ära, ei viitsi selle käruga ise enam tegeleda. las otsivad ise seda viga siis.
WVP
postitati 14.12.11 18:53 Tsiteeri
Vänt paika, Pump märgis ja ei usu et nukkasid ära tõmbas, siin ju ei ole keegi sellise probleemiga tegelenud, ütlete muudkui mulle et süüde paigast ära.
Vot täpselt nuka koonuse pealt liigutab niipalju süüte ära, et mootor enam korralikult ei käi.
Miks sa arvad, et keegi pole sellise probleemiga tegelenud?
Ma ei anna ju lampi vihjeid, milles mul pole kogemusi, kindlasti on siin ka niisama targutajaid.
Gemmu
Auto: Audi A6
postitati 14.12.11 18:58 Tsiteeri
nii. selge. oletame et tõesti auto läheb ilusti käima jne. aga ikkagi süüde paigast ära. siis kuidas ma käituma peaksin kuidas ja mida ma kontrollin ja kas piisab süüte varasemaks keeramisest ainult või pean midagi muud ka veel jälgima/tegema
mingi manual. minu õpetamiseks?
WVP
postitati 14.12.11 19:18 Tsiteeri
mis moodi sa väntvõlli "märk paigas"kontrollisid?
Gemmu
Auto: Audi A6
postitati 15.12.11 05:52 Tsiteeri
Alt Lukustasin tollle ära. /auto alt. selleks ettenhtud kohas.
ferdinand
Auto: 400,401,969
postitati 15.12.11 10:05 Tsiteeri
Koonuse pealt ta küll "süüdet" ära ei liiguta, ilma muud "liigutamata", isegi teoreetiline võimalus selleks puudub.
Edit: jh tegelt ju pumbaratas ka koonuse otsas. Ma küll ei kujuta ette, et mismoodi see saab koonuse otsast lahti tulla ja siis taas kinni jääda.
Gemmu
Auto: Audi A6
postitati 16.12.11 08:47 Tsiteeri
Algselt postitas: ferdinand
Vot selleni ma tahtsingi jõuda, et minujaoks võimatu et nii ära tõmbaks, ja räägi otsast peale kuidas ma selle probleemiga algust tegin.
Pärnu-Viljandi mnt.algus
Viljandi- Paide mnt. keskpaiku
Paide-Rakvere mnt. põhimõtteliselt kodus 30 kilomeetrit enne rakvere
sõidan rahulikult mingeid probleeme ei ole, tekkis möödasõit. siis andsin gaasi juurde, rekkaga kõrvuti olles käis korra jõnksatus läbi,(teadsin kohe et filter umbes, kuna olen varem sama asja tunda saanud, et õhumullid jooksevad filtris/voolikus ringi kui vähe rohkem gaasi annan) igaksjuhuks tegin kapotti lahti ja märkasin gaasi lisamisel et jooksevad jah vahepeal õhumullikesed läbi.
Jätkasin sõitu, koju jõudes oli asi nii hull et iga väiksemgi gaasi lisamine hakkas lollitama autoga, noh põhimõtteliselt jõudu tal ei olnud (pimedas ei näinud ega osanud vaadata ka kas ta suitseb)
Järgmisel hommikul vahetasin filtri ära( autot enam käima ei saanud tükk aega)
vedasin auto töökotta paela otsas ning hakkasin uurima kus mul viga on
lõpuks kui käima sain siis turtsus ja ja ajas vingugaasi välja smmutist, ja sellest ajast saadik olen siin teie arvamusi küsinud, ja küige tõenäolisem asi hetkeseisuga ongi too ENNAKO kolb.
Ei ole olnud nii et asi JÄRSKU akkas jünksutama ja pöörde enam ei läinud, lihtsalt jrgmine hommik ma enam sõita ei saanud autoga.
ferdinand
Auto: 400,401,969
postitati 16.12.11 10:43 Tsiteeri
Kui keegi tegeleb selle "ennako" kolviga, kas oleks võimalik teha pilte või mingit täpsemat kirjeldust tööde kulgemisest? Või on sellest pumbast mingeid peenemaid jooniseid kuskil üleval?
Tegelikult võib olla umbes 100 erinevat viga, mina arvan, et "süüte" oma õigelt kohalt lahkumine on üks ebatõenäolisematest. Ega keegi eriti nõu anda ei oska, kuna nende mootorite hingeelu lihtsalt ei tunnegi pea keegi. Pritsehetke reguleerimise kolvi olukorda (ja enamusi muid asju) peaks minu arusaama järgi olema võimalik üsna üheselt diagnoosida ilma masinat seibideks võtmata.
See 00550 mis viitab mingile pritse veale käivitamisel, ei tarvitse, nagu ma aru olen saanud, üldse mitte pritsehetkega seotud olla. Sama viga võib näidata, kui kütus pumbani ei jõua vmt puhul, a sellest oli juba juttu.
Pmst võib ju paigast ära gaasijaotus ka midagi sarnast põhjustada, kuigi see on veel ebatõenäolisem, kui pritsehetke nihkumine.
A kas "süüte" muutmine tekitas mootori töös mingeid muutusi või mitte?
Fugitive
Registreerunud 12.02.06
postitati 16.12.11 11:01 Tsiteeri
Selle koodiga seoses:
1. Kontrollida kas kütust tuleb peale. (Mina võtsin filtri küljest lahti vooliku mis pumba sisse jookseb ja lasin starterit - filtrist hakkas kütust pritsima).
2. Kontrollida tagasivoolu torustik - üks võimalus on filtri küljest lahti võtta toru ja puhuda sellesse (kas õnnestub paagini puhuda või mitte).
3. Mingisuguse pumbaga või pritsiga suruda kõrgsurvepumba sisendvoolikusse kütust samal ajal starterit ringi ajades (kui läheb käima siis ilmselt pump ei suuda ise kütet imeda ja on katki, kui ei lähe siis viga mujal).
Targad räägivad, et enamjaolt antud veakood tähendab pumbariket (minul oli täpselt nii) ja sümptomid olid täpselt samad - algul rohkem gaasi vajutades tegi jõnksu siis suurema jõnksu siis hakkas puterdama ja ei kannatanud üldse sõita jne.
Kalle-
postitati 16.12.11 14:00 Tsiteeri
Siin midagi on PDF-i kujul ja saksa keeles.
ferdinand
Auto: 400,401,969
postitati 16.12.11 17:01 Tsiteeri
Algselt postitas: Kalle-
Sehr gut, danke, sellist infot peakski siin rohkem levitama.;)
Kui seibideks peab pumba jupitama, et jutuks olnud kolbi kätte saada ja üht "tüüpviga" kõrvaldada? On keegi reaalselt seda ise teinud või käivad kõik revalist miljoni eest abi otsimas?
WVP
postitati 16.12.11 17:55 Tsiteeri
Ok. ma rohkem ei kkirjuta, siin niigi targad koos.
Võiks olla kohustuslik pädevus test, enne kui hakatakse auto remondi teenust pakkuma.
ferdinand
Auto: 400,401,969
postitati 17.12.11 01:11 Tsiteeri
Täiesti iseenesestmõistetav oleks selline asi arenenud maailmas. Mitte nii, nagu meil siin, et sportlased hakkavad ühtäkki taarakäitlemise üle otsustama vmt.
Eestis ongi see "auk" tühjaks jäänud, st mitte keegi ei oska (või ei taha) sellistele masinatele dagnostikat ja mõistliku hinnaga "raviteenust" pakkuda. Kes nüüd on esimene ja selle tühimiku täidab?;) Kui autoremonditeenuse pakkujad ei viitsi ega taha mõistliku hinnaga teenust pakkuda, siis võin vaid oletada, et varsti võib mõni uus tegija hakata pakkuma normaalse hinnaga diagnostikat V6 mootoritele,(ja aja jooksul ka teistele), küsimus on vaid väljaõppe kvaliteedis ning ajas. Hetkel on minu nägemuse järgi see auk turul täielikult täitmata.
Kalle-
postitati 17.12.11 01:40 Tsiteeri
Noh, mis kärbes sind hammustas? Ja kes siin teenust pakub?
Teemasse ka natuke.
Nimelt maadlen praegu sama mootori käivitusprobleemiga. Tahtis pikka käiamist saada nii soojalt, kui külmalt. Panin süüdet varasemaks, tundus parem. Kuna pumpa täpselt paika panna ei saa (keegi on pumbapoolse augu umbseks teinud) panin hamba jagu varasemaks, pumbarattast enam ei saanud. Pagan, nagu võtit keerasin, kohe käis aga mitte kauaks. Pikapoolne käivitus tuli tagasi aga pöördesse läks ja tömmet oli tunde järgi parasjagu. Tulemuseks oli kood 00550 ja käigukast avariis. Taastasin endise seade.
Jutu mõte selles, et kui juba vale süütega käima läheb, peaks ka pöördesse minema.
Ei tea, kas Germo leidis lahenduse, kuna küsimusi pole. :D Oli saadetud PS abiks?
Ära probleemi lahenemisel ära kao!:D
Gemmu
Auto: Audi A6
postitati 17.12.11 08:26 Tsiteeri
Ei olen endiselt olemas, oeh. ei saa magada ka enam, näen seda totrust juba unes.
Peetis on ml ka õhulugeja nüüd.
Jah tõesti mul on ka veakood et läheb avarii reziimi. aga ei pannud talle tähelepanu miks, igatahes olen ma 6K manuaali omanik. ei tea. seletamatud jõud :D. aga ta viskab mu peale käivitamist avariisse kui olen natuke proovinud jälle lisada gaasi algul naq läheb pöörde natsake u 3400 pöördemomenti ja siis väänab end avariise ja jääb sinna 2200 kanti. nii. võiksime teha nüüd hooopis nii et hakkame nulllist. Oletame et auto hakkas jukerdama niimoodi eile. ja hakkame järjest tulema mida võiksin uuesti otsima hakkata. ilmselgelt uut õhulugejat. aga jah, teeme etapp etappi järel.
1.Uus õhulugeja(kellegil pakkuda?)
2. ...
3. ...
4. ...
Jään ootama teiepoolseid pakkumisi mida ja kuidas käitun edasi. Vb jäi mul midagi kahesilma vahele, võiksime üle vaadata. kerge manuaal võiks ka visata kui olemas. kui midagi teen.
Fugitive
postitati 17.12.11 10:46 Tsiteeri
See vist oli kivi minu kapsaaeda. Kirjutasin sinna need punktid mis käivad koos antud veakoodi kirjeldusega nii ross tech lehel kui ka erinevates VAG-foorumites. Sa võiksid ise ka selgitada kuidas sinu soovitus võiks aidata auto korda teha? Ehk sinu arvates on "süüde" (mida diiselmootoril reaalselt ei ole) vale ca "paar" kraadi ja sellepärast ei lähe käima. Kuidas ta siis sõitu alustades vale "süütega" käis? Algul ju lihtsalt jätab õrnalt vahele kuid probleem süvenes ja lõppes sellega, et ei lähegi enam käima.
 Lehekülgi:  1  2  3  4
[PHP: 15.2% - SQL: 84.8%]
