postitati 11.07.19 09:45 |
Puhastus siinkohal ei aita, vaata ikka veakoodi ka, see ju ütleb selgelt, kus ja mis viga.
jipikaje
postitati 11.07.19 08:30 |
Tere
Hiljaaegu tagasi hakkas armatuuris põlema mootorituli, ning peale arvuti järgipanemist leidsin sellise vea:
5475 - Intake Manifold Tuning Valve Control Circuit
P1028 00 [168] - Open Circuit
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 195790 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 49 °C
Intake air temperature: 25 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.720 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 11940 mV
Intake manifold flap activation: 12.60 %
Intake manifold flap feedback: 1.04 %
Intake manifold flap output stage: 0.00 %
Coolant temperature: 49.5 °C
Kas oleks mõistlik lasta klapid ära puhastada?
Aitäh!
