S - Audid
V8 & V8 BiT - (4.2 V8 ja 4.2 V8 BiT)
C5 A6 V8 sisselaske kollektori klapid kinni (ka C5 S6 ja A8 V8)
[quote][i]Algselt postitas: Maku[/i] Teemakohast infot: http://www.autozine.org/technical_school/engine/tech_engine_2.htm#Variable-Intake [i]Variable length intake manifolds is commonly used in sedans. Most designs employ 2 intake manifolds with different length to serve each cylinder. [b]The longer one is for low-speed use. The shorter one is for high rev. It is easy to understand why high speed need a short manifold, because it enables freer and straightforward breathing. But why does it need longer pipe for low speed ? because longer pipe results in lower frequency of air mass reaching the cylinder, thus matches the lower rev of engine very much. This provide better cylinder filling, thus improves torque output. Besides, longer intake manifold leads to slower air flow, hence better mixing between air and fuel. [/b][/i] [/quote]
S - Audid
22
34.1%
65.9%
