Firmade sooduspakkumised & makstud reklaam
Race.Fi: Product topic
[quote][i]Algselt postitas: Race.Fi[/i] [b]Japan Racing wheels can be bought also as "custom"[/b] In addition to the standard range of Japan Racing wheels, many wheel models can also be ordered with the desired bolt pattern and ET number as "custom". In this way, models that have run out of stock, for example, may be ordered little bit faster. [url=https://www.race.fi/en/cat/951/jr-wheels/1][img]https://s.race.fi/media/wheels_en.jpg[/img][/url] JR is undoubtedly the most popular wheel brand of this spring, they have a terrific look and the quality is at least very good. Delivery is also quite fast, the wheels that are in the factory stock rarely takes more than one week to deliver at least in near of big cities. As said, several Japan Racing models can also be purchased as "custom", the bolt pattern and the ET number can be decided by you (ET is usually set to a certain range where to choose from). [b][u]Wheel offset:[/b][/u] Wheel offset is the distance in millimeters from the hub mounting surface to the center line of the wheel. A positive / bigger offset is when the hub mounting surface is toward the front or outwards of the wheel. Negative / smaller offset is when the hub mounting surface is toward the back or brake side of the wheels center line. Offset can also be zero, then the hub mounting surface is even with the center line of the wheel. Bigger = wheels sit more inwards. Smaller = wheels come out more. Wheels includes also model specific hub centric rings and center cups. [b]Order Japan Racing wheels from here with comprehensive payment methods[/b] »» [u][url=https://www.race.fi/en/cat/951/jr-wheels/1]Race.fi: Japan Racing wheels[/url][/u] [b]Japan Racing bolts and nuts[/b] »» [u][url=https://www.race.fi/en/cat/995/japan-racing/1]Race.fi: Japan Racing bolts and nuts[/url][/u] Have a great weekend! -Riku [/quote]
48.4%
51.6%
