Elektroonika
kompuutri paigaldus
[quote][i]Algselt postitas: Zoig[/i] [quote][i]Algselt postitas: Originalstw[/i] Vanad olid minichekiga. Saaks nüüd vaid teada mis juhe too on. Pirni ka ei taha välja keerata... siis ei näe õlituld ja muid selliseid asju mida tegelikult vaja oleks. [/quote] See peaks olema pistik, mis autochekile vastavaid tarkuseid jagab. Contacts on 26-pin, green multipin connector on dash panel insert [list=1] [*]Negative from warning contact for brake fluid level [*]Negative for engine electronics malfunction (only with mini-check system) [*]Negative for coolant temperature too high [*]Not used [*]Negative from 0.3 bar oil pressure switch [*]Negative from brake linings [*]Terminal 15 [*]Not used [*]Not used [*]Negative for warning lamp no.14 (charge warning) [*]Terminal 31 [*]Input from engine control unit for rev counter (rev counter signal) [*]Not used [*]Negative from 0.9/1.8 bar oil pressure switch - 4-/5-cylinder engine: 1.8 bar oil pressure switch - 6-cylinder engine: 0.9 bar oil pressure switch - Checking => Page 90-62 [*]Vehicle speed signal (output) [*]Negative for coolant temperature gauge [*]Negative for indicator lamp no.12 (Diesel/CAT) [*]Not used [*]Not used [*]Not used [*]Not used [*]Not used [*]Not used [*]Terminal 31 (coding for 5 cylinders) [*]Not used [*]Not used[/list=1] [/quote]
Elektroonika
kompuutri paigaldus
33.7%
66.3%
