Pealkiri: veakood (Vastuseid: 3 | Vaatamisi: 1482)
jyrka
Registreerunud 10.07.03
postitati 13.07.04 19:38 Tsiteeri
veakood
kuidas saab ise lugeda seda veakoodi või oskab keegi öelda mis on veakood 61
quattromees
Registreerunud 07.01.03
postitati 13.07.04 19:41 Tsiteeri
Esialgne postitaja jyrka
Mis autol veakoodi lugeda vaja on? Metoodika veidi erinev mudelilt mudelile. Minu teada veakoodid peaks olema neljakohalised.
Kokku rohkem, kui 1100 hobust
jyrka
postitati 13.07.04 19:42 Tsiteeri
autoks audi 80
quattromees
postitati 13.07.04 19:44 Tsiteeri
autoks audi 80
Ära ole tagasihoidlik, täpsemalt, täpsemalt! Mootor, aasta jne!
Lisan mõningad veakoodide tähendused:
1111
Fuel Injection Control Unit (FICU) or Ignition control unit (ICU) Defective
Check vehicle electrical system grounds, Replace control unit if no wiring or +12V supply faults found
1231 (1989-91 Audi 100 only)
Transmission speed sender (G68), Signal used by Ignition Control Unit (ICU), check sensor output
2121
Idle switch
Switch open ckt, stuck closed
Switch defective, mechanical linkage problem, or wiring problem
2122
Engine speed sensor signal missing
Signal used by Ignition Control Unit,
Open or short circuit,
Defective sensor & cables, metal fragments on flywheel teeth,
2123
Full load/full Throttle switch
Switch defective, mechanical linkage problem or wiring problem
2132 1989-91 Audi 100 Only
Data Wiring Defective, check wiring (California Vehicles only)
2141
Knock regulator
Regulator limit exceeded, Excessive knock, timing is being retarded by maximum amount,
Fuel octane too low, Excessive Compression, carbon build up in combustion chamber
2142
Knock sensor
Open or short circuit, Defective sensor
Check sensor and wiring
Symptom: Timing retarded, High fuel consumption, power loss,
2223
Altitude Sensor defective, check sensor output and wiring
2232
Air Flow Meter plate rotary Potentiometer (resistive Sensor) defective, check sensor output and system wiring
2233
Air Flow Sensor Reference voltage
2312
Coolant sensor
Defective sensor or wiring
Symptom: Cold starting difficulties at low temperatures, Poor idle and acceleration during warm up
2341
Oxygen Sensor Control Regulating Limit exceeded
2411 1989-91 Audi 100 only
Exhaust Gas Recirculation Valve, (California Vehicles only)
4431
Idle Stabilizer Valve (ISV), Signal used by Ignition Control Unit
4444
No Faults have been recorded.
0000
End of Diagnostic Output, code 0000 is signaled by the Check Engine or LED light coming on for 2.5 seconds, and then being off for 2.5 seconds
[PHP: 39.8% - SQL: 60.2%]
