Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - kliima display vilgub
Pealkiri: kliima display vilgub (Vastuseid: 27 | Vaatamisi: 5322)
veljo5
Registreerunud 26.04.05
postitati 22.10.05 12:38 Tsiteeri
et kui kas lööd nipsu vastu kliimat või vajutad kõvasti mingit nuppu siis lööb jälle kirja ett muidu valgustus põleb aga aint kirjasi ei ole ees
milles on viga ja palju remont maksab
preedrik
Registreerunud 13.09.05
Auto: Audi 200 TQ 10v
postitati 22.10.05 12:48 Tsiteeri
mis masinaga tegu ja mis aasta?
Ei ole mõttet sangarit panna:cool:
A4TQ
Registreerunud 24.07.03
Auto: SQ7, 911
postitati 22.10.05 18:27 Tsiteeri
Võtad displei maha,otsid mõne elektrooniku või telekaparandaja.See konadik puhastab su displei ära ja joodab mõned kohad üle.Siis töötab jälle. :D
audi2.8
Registreerunud 01.12.05
Auto: Audi a4 2.8 quattro
postitati 02.12.05 16:58 Tsiteeri
Käisin esinduses ja seal öeldi et siis on kliimaga jama kui tuled vilguvad displeil.
Rainis
Registreerunud 08.01.05
Auto: Lancer
postitati 02.12.05 19:07 Tsiteeri
Varsti ei ole enam vajutamistest ja nipsutamisest ka mingit tolku. Hakkab vilkuma nii nagu ise heaks arvab.
Mul oli/on sama jama kuid kliima töötab endiselt korralikult.
tarmo
Registreerunud 05.01.03
postitati 02.12.05 19:09 Tsiteeri
Algselt postitas: audi2.8
kliimaga ei ole miskit jama, lihtsalt kuskilt ei saa asi sul aegajalt kontakti!
kui ise ei oska, siis A4TQ soovitus abiks
prix666
Registreerunud 24.04.06
Auto: A6Q
postitati 02.01.07 19:51 Tsiteeri
Tundub, et kliimablokk üks nõrk koht, oma a4-l sama asi, et põleb aga kirju pole, kui vajutada display nurgapeale siis viskab pildi ette korraks.
Otsustasin siis ise viga otsida, kõigepealt kliimablokk konsoolist välja monteerida
kliimablokk
ja juppideks võtta
Viga ei tulnudki kaua otsida :) Selgus, et pistiku jootekohad on mikroskeemiplaadi pealt lahti põrunud
Kahjuks ei võimaldanud fotokas lähemalt pilti teha, oleks mõrad paremini näha.
Nüüd ettevatlikult väikse kolviga ülejoota ja jälle töötabki :)
Rene66
Registreerunud 20.09.06
Auto: A4 quattro
postitati 13.01.07 02:31 Tsiteeri
Algselt postitas: prix666
kliimablokk
ja juppideks võtta
Mul on jama kliima-ikooniga (display vasakus allnurgas, sarnanes vist jääkristalliga), kui hoian nuppu all siis põleb, nii kui lahti lasen nupu, kustub ka ikoon. Temperatuuri näitab ja saab ka reguleerida, aga lühikestel linnaotsadel saa nüüd aru, kas kliima ehk konditsioneer ka järgi on. Peaks vist autos ühe jooma maha pidama, vaatab kas imeb aknad kuivaks:D Kas samuti tuleks jootekohad üle vaadata ?
Pikkpoizz
Registreerunud 12.09.05
Auto: Kia Sportage 2006.a. Honda CR-V 2016.a.
postitati 13.01.07 08:06 Tsiteeri
Algselt postitas: Rene66
kliimablokk
ja juppideks võtta
Konditsioneeri minu teada alla +5 kraadi ei võtagi järgi s.t et jahutada ple tal midagi seal, ja seda kristalli kujutist ei teki.
Rene66
Auto: A4 quattro
postitati 13.01.07 22:32 Tsiteeri
mlleks see nupp siis on, ja mida ta sisse lülitab ?
Leidsin juba vastuse foorumist, et kui on temp alla +5 siis kliima kompressor ei käivitu.
kaaarel
Registreerunud 04.11.06
Auto: Audi A4 `95
postitati 18.01.07 20:31 Tsiteeri
see nupp on kliima sisse lülitamise jaoks..
aga kliimat saab kasutada siis, kui temp on väljas üle viie plusskraadi..
Rene66
Auto: A4 quattro
postitati 19.01.07 02:58 Tsiteeri
tnx. ja nii ongi, mure murtud:D
jaakk
Registreerunud 23.07.07
Auto: Bmw 525i -2007, sedaan
postitati 07.01.08 13:15 Tsiteeri
Minu mure järgmine, et kliima display taust vilgub (dimmer nagu ei töötaks) st kui tuled põlema panen, siis taustavalgus kliimal läheb tuhmimaks aga vahest viskab ikka ennast heledamaks ja see häirib.. samuti on kliimal selline tore asi, et temp on HI peal ja vent on 1 pulk siis auto soojenedes paneb ise vendi pöördeid juurde kuniks punn põhjas juba, kuigi vent on man -i peal..
Peaks ühendused üle jootma?
raino84
Registreerunud 29.12.05
Auto: Audi A6 Allroad 2,7Tdi, 140kw, 09
postitati 07.01.08 13:32 Tsiteeri
Algselt postitas: jaakk
Minu mure järgmine, et kliima display taust vilgub (dimmer nagu ei töötaks) st kui tuled põlema panen, siis taustavalgus kliimal läheb tuhmimaks aga vahest viskab ikka ennast heledamaks ja see häirib.. samuti on kliimal selline tore asi, et temp on HI peal ja vent on 1 pulk siis auto soojenedes paned ise vendi pöördeid juurde kuniks punn põhjas juba, kuigi vent on man -i peal..
Sa vist tahtsid öelda, et "siis auto soojenedes paneb ise vendi pöördeid juurde kuniks punn põhjas juba.
Sama asi mul ka... Paned tempi sinna 24 peale näiteks istuma ning mingi hetk hakkab ise venti juurde uhama:S
jaakk
postitati 07.01.08 13:44 Tsiteeri
Vabandust jahh, nii see on, kuigi ei tohiks niimoodi olla.
Cari
Registreerunud 22.08.07
Auto: Audi A6
postitati 07.01.08 15:49 Tsiteeri
ma olen ka täheldanud seda automaatset juurdepanekut, samas kui ise olen ventilaatori tugevuse 1 pulga peale pannud.. äkki on mingi inseneride trikk? :P
j2mis
Registreerunud 07.01.07
Auto: C5, B5, Zafira A
postitati 07.01.08 16:12 Tsiteeri
Kui külma mootoriga puhur esimese pulga peal on. Siis jahutusvedeliku/mootori soojendes tõstab kliima juhtblokk puhuri kiiruse astmeid seni kuni on saavutanud maksimumi.
Kuna külma õhku pole ju mõtet salongi puhuda.
Näiteks: kliima pealt 29 kraadi. Mootor töötab külmalt. Jahutusvedelik hakkab saavutama 29 kraadi, tõuseb automaatselt sammhaaval salongipuhuri kiirus. Jahutusvedeliku piisaval soojenemisel tõuseb puhuri kiirus maksimumini.
kuno666
Registreerunud 15.07.06
Auto: 2xV8 & 1x 2,2 20v.
sama asi mull ka et paneb ise juurde aga mind see küll ei sega ma panen klaasile puhuma ja siis salongi ja rohkem polegi vaja. Minuarust võib ta seal ennast nii palju tiommida kui tahab pea asi et parajalt soe oleks
jaakk
postitati 08.01.08 07:55 Tsiteeri
Ok, las paneb ise pöördeid juurde, kuid siiski miks ta vilgub lambist (taustavalgus heledamaks, kuigi peaks konstantselt tumedam olema, kui sõidutuled põlevad).
kiin21
Registreerunud 17.10.05
Auto: Audi
postitati 20.01.08 16:21 Tsiteeri
Minulgi viga kliima valgustusega,mida aeglasemalt vent töötab seda tuhmim valgus on ja mida suuremad pöörded vendil seda valgemaks läheb.milles asi?
jaakk
postitati 20.01.08 16:25 Tsiteeri
See on raudselt kliimabloki külmjoode.
Võta jootekolb kätte ja lase ühendused üle.
Minu oma teeb veel lisaks sellist trikki, et kui siseõhu peale panna, siis enamasti viskab automaatselt kondi järgi (isegi +2,5 kraadiga).
Algselt postitas: kiin21
postitati 20.01.08 16:32 Tsiteeri
siis ei ole sul ainuke.olen täheldanud,et endal teeb seda sama-see siseringluse teema siis.
lunatic
Registreerunud 20.02.05
Auto: A4 allroad ja Volvo C70
postitati 20.01.08 16:38 Tsiteeri
See on ju väga abiks lisa. Kuivatab salongiõhu niiskust ära. Ja helbekesest saad ju välja lülitada :)
-anc-
Registreerunud 09.05.05
Auto: 2017 A5 Cabrio
postitati 03.10.08 07:47 Tsiteeri
aga kas see on normaalne et siseringluse saad lülitada vaid siis kui kont järel(lumehelbeke põleb)?
erki.t
Registreerunud 06.07.06
Auto: Got burger? (Jeep)
postitati 03.10.08 10:12 Tsiteeri
ilma kondita siseringlust lülitades on enamusel aastaaegadel lootus üsna kiirelt istuda uduste akendega autos.
[PHP: 22.6% - SQL: 77.4%]
