Pealkiri: Audi A6 c6 2005a 2.4 130kw ABS/EPS fault & parking brake malfunction (Vastuseid: 4 | Vaatamisi: 1028)
Randyman
Registreerunud 23.12.16
postitati 08.06.23 15:20 Tsiteeri
Tere,
armatuuril põlevad ABS, ESP ja elektrooniline seisupiduri märgutuli. Nüüdseks põlevad püsivalt.
Kas keegi vähe pädevam oskab mulle selgitada alljärgnevaid veakoode ja millest viga otsida(kahtlustan ise vigast ABS moodulit):
Mileage: 378590km-235244mi Repair Order:
Address 01: Engine Labels: 06E-910-552-BDW.clb
Control Module Part Number: 4F0 910 552 R HW: 4F0 907 552 D
Component and/or Version: 2.4l V6 MPI 0010
Software Coding: 0105000302170920
Work Shop Code: WSC 02325 785 00200
VCID: 3261470AAD2F69DF57-8066
4 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 16
Reset counter: 40
Mileage: 378528 km
Time Indication: 0
Date: 2005.02.01
Time: 12:23:46
Freeze Frame:
RPM: 704 /min
Mass Air / Rev.: 119.9 mg/str
Temperature: 94.5°C
Idle
Load: 26.7 %
Speed: 0.0 km/h
005648 - Internal Control Module
P1610 - 006 - Memory Check Sum Error - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 378548 km
Time Indication: 0
Date: 2005.02.01
Time: 12:00:14
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 4.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
009523 - Ignition Switch; Run/Start Position Circuit
P2533 - 006 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 7.5°C
Engine Off
Voltage: 8.98 V
Speed: 0.0 km/h
005137 - Secondary Air Injection System; Bank 2
P1411 - 007 - Insufficient Flow
Freeze Frame:
Fault Status: 01000010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 378576 km
Time Indication: 0
Date: 2005.02.01
Time: 12:20:41
Freeze Frame:
RPM: 832 /min
Mass Air / Rev.: 179.9 mg/str
Temperature: 21.0°C
Idle
Load: 43.9 %
Speed: 0.0 km/h
Readiness: 0000 0000
Address 53: Parking Brake Labels: 4F0-910-801.clb
Control Module Part Number: 4F0 910 801 HW: 4F0 907 801
Component and/or Version: EPB C63C0030 H03 0030
Software Coding: 0002031
Work Shop Code: WSC 02334 785 00200
VCID: 5DBBC4B6843186A7DA-8008
1 Fault Found:
01316 - ABS Control Module
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 81
Mileage: 378544 km
Time Indication: 0
Date: 2005.02.01
Time: 12:58:38
Freeze Frame:
Voltage: 12.73 V
Count: 231
Monday,08,May,2023,15:33:15:00008
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.2 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 81
Mileage: 378544 km
Time Indication: 0
Date: 2005.02.01
Time: 12:58:38
Freeze Frame:
Voltage: 12.73 V
Count: 231
siLc
Registreerunud 05.06.10
Auto: 2011 VW Passat EcoFuel
postitati 09.06.23 11:12 Tsiteeri
Kus siis ABSi veakoodide väljavõte on? Veakood mootoris ja kässari ajus nende olemasolule viitavad.
Randyman
postitati 09.06.23 15:39 Tsiteeri
Algselt postitas: siLc
Tere,
Millele võiksid veakoodid viidata?
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 40
Mileage: 378528 km
Time Indication: 0
Date: 2005.02.01
Time: 12:23:46
Freeze Frame:
RPM: 704 /min
Temperature: 94.5°C
Idle
Load: 26.7 %
Speed: 0.0 km/h
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 81
Mileage: 378544 km
Time Indication: 0
Date: 2005.02.01
Time: 12:58:38
Freeze Frame:
Voltage: 12.73 V
Count: 231
teet82
Registreerunud 17.11.13
postitati 09.06.23 18:06 Tsiteeri
Kui ABS moodul ise arvutiga ei suhtle, siis tõenäoliselt on see vigane. Kõige lihtsam on samasugune plokk pistikusse toppida ja uuesti arvutiga ühendust testida.
postitati 09.06.23 19:48 Tsiteeri
Selleks tuleb katsetataval aju eraldada muust rauast, muidu ei mahu. Ja kui vana mooduliga ühendust pole, siis uue koodi koostamisega hakkama ei saada, eriti kui selliseid küsimusi küsida märkamata, et abs ei suhtlegi millegiga.
Rossi Uwe ütleks selle peale, et saada full scan, muidu võid nõu küsida sealt, kust kaabli ostsid e.s. Väikeselt hiinlaselt.
OOOO, VW, Seat, Skoda DIAGNOSTIKA, OSTUABI (võimalik üle Eesti), kodeerimine, (de)aktiveerimine, aut. kastide adaptsioonid, õhkvedrustuse mured jne. (Litsentsiga orig. Ross-Tech PRO V2 seade + uusim tarkvara VCDS 24.5.0 + pikk kogemus). 2g, HN+, MHI2, MHI2Q uuendused, NAVI 2024, VIM, SpeedCam, Carplay, Android Auto aktiv. jne. Läbitud kilomeetreid ei muuda. U2U või 55547002.
[PHP: 75.9% - SQL: 24.1%]
