Pealkiri: Generaatori anomaalia (Vastuseid: 5 | Vaatamisi: 2193)
Sqip
Registreerunud 14.07.13
Auto: Audi A6 C7 3.0TDi 200kw
postitati 23.03.18 18:04 Tsiteeri
Tere
Autoks A6 C6 2.7tdi
Aku tuli läks armaturis põlema ja kui sõites pöörded kuskil 4000 lasta kustub ära. Kui sõidust tulla ja kohapeal seistes mootor käib siis läheb uuesti aku tuli põlema.
Kas on keegi sellise nähtusega kokku puutunud, või teab mida arvata. korraks pandi kaabel ka külge ja sealt tulid sellised veateated.
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4F2 910 401 S HW: 4F0 907 401 B
Component and/or Version: 2.7L V6TDI G000AG 0010
Software Coding: 0011372
Work Shop Code: WSC 80093 222 69422
VCID: 2E5578E3B995976E391-807B
1 Fault Found:
053255 - Please check Fault Memory in Battery Monitoring Module
U1007 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 301439 km
Time Indication: 0
Date: 2018.03.21
Time: 11:39:56
Freeze Frame:
RPM: 1680 /min
Torque: 156.0 Nm
Speed: 94.1 km/h
(no units): 969.0
Voltage: 11.55 V
Temperature: -6.3°C
(no units): 4.0
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Control Module Part Number: 4F0 910 181 E HW: 4F0 915 181 A
Component and/or Version: J0644 BEM H12 0590
Software Coding:
Work Shop Code: WSC 38563 123 51443
Additional Info: 000915105CF von VA0 6541910629
Additional Info: Geraet 51443
VCID: 234399D7E2572A06A6F-8076
4 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 300718 km
Time Indication: 0
Date: 2018.03.05
Time: 07:27:02
02252 - Generator
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 10
Reset counter: 147
Mileage: 300981 km
Time Indication: 0
Date: 2018.03.17
Time: 12:23:30
00992 - Consumption Cut-Off Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 300982 km
Time Indication: 0
Date: 2018.03.17
Time: 12:30:37
02479 - Partial Consumer Shut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 301431 km
Time Indication: 0
Date: 2018.03.21
Time: 11:34:48
teet82
Registreerunud 17.11.13
postitati 23.03.18 18:26 Tsiteeri
Kui tuli põleb, siis arvatavasti ei lae sellel hetkel, seda näitab ka 11.55V pinge "Freeze Frame" all.
Mis siin ikka pikalt mõelda, generaator maha ja harjad esimese asjana üle vaadata, suure tahtmise korral saab ka generaatorit maha võtmata harjad kätte, mootoripadi eest jne.. Sõbra 3.0TDI genekale sai hiljuti uued harjad tinutatud, kulu paar eurot ainult. Soovitaks pigem vana remontida, poest vahetusfondiga tulevad mingid kahtlased käkerdised.
ragenor
Registreerunud 21.05.14
Auto: A8L 4.2, B4 2.0E
postitati 23.03.18 19:13 Tsiteeri
Mul peaaegu sama teema. Kui autot käivitan, siis laadima enne hakka kui veidi pöördeid lisan. Kui mootor on soojaks sõidetud, siis seda jama ei esine.
Sqip
postitati 23.03.18 22:44 Tsiteeri
Tänud. Eks siis lasen kuskil generaatori üle vaadata.
Sqip
postitati 24.03.18 15:02 Tsiteeri
Oskab keegi öelda millisede harjad (pingeregulaator) sellele genekale läheb ja kust tellida?
Andmed:
059903015R
180A VW AG
TG17C020
2542784B
705165773
VALEO
ragenor
postitati 24.03.18 20:10 Tsiteeri
Miks näiteks oma auto VIN koodiga kuskilt autovaruosa poe uksest sisse ei marsi, suht kindel et sellist asja ei ole küll vaja tellida.
[PHP: 66.8% - SQL: 33.2%]
