oll555
Registreerunud 08.02.06
postitati 24.02.18 20:20
Mure 3.0 tdi bmk
Sai vahetatud pihusti seibid ja küt.filter.
Nüüdsiis põõrdel ca. 2000 jõudu pole ja rõngad süttivad.Kütuse surve madal.
Veakoodid
004195 - Fuel Pressure Regulation
P1063 - 001 - Control Range Not Reached - MIL ON
Freeze Frame:
Fault Status: 11110001
Fault Priority: 0
Fault Frequency: 23
Reset counter: 255
Mileage: 373086 km
Time Indication: 0
Date: 2018.02.20
Time: 18:50:00
Freeze Frame:
RPM: 2331 /min
Torque: 487.5 Nm
(no units): 5.0
Voltage: 13.76 V
Pressure: 674.5 bar
Duty Cycle: 50.9 %
P1063 - 002 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 23
Reset counter: 255
Mileage: 373086 km
Time Indication: 0
Date: 2018.02.20
Time: 18:50:00
Freeze Frame:
RPM: 2331 /min
Torque: 487.5 Nm
(no units): 5.0
Voltage: 13.76 V
Pressure: 674.5 bar
Duty Cycle: 50.9 %
P1063 - 004 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 23
Reset counter: 255
Mileage: 373086 km
Time Indication: 0
Date: 2018.02.20
Time: 18:50:00
Freeze Frame:
RPM: 2331 /min
Torque: 487.5 Nm
(no units): 5.0
Voltage: 13.76 V
Pressure: 674.5 bar
Duty Cycle: 50.9 %
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 002 - Signal too High (Rich)
Freeze Frame:
Fault Status: 01110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 373215 km
Time Indication: 0
Date: 2018.02.22
Time: 00:32:05
Freeze Frame:
RPM: 1596 /min
Torque: 0.0 Nm
Speed: 90.7 km/h
Duty Cycle: 1.0 %
Duty Cycle: 35.9 %
(no units): 0.0
(no units): 16.0
Readiness: 1 2 0 0 0
Lekkeid ei ole.
On mõtteid millest alustada?
TarmoValk
Registreerunud 27.06.14
Auto: Audi A6 3.0TDIQ
postitati 03.03.18 13:43
Ei tundu sama teema, kuna n290 on probleemid pigem väljasuremisega jne.
Vihje 12.12 diagnostikule, hammasrihm on kontrollitud? Vahetatud kunagi?
(Litsentsiga orig. Ross-Tech PRO V2 seade + uusim tarkvara VCDS 23.11.0 + pikk kogemus). 2g, HN+, MHI2, MHI2Q uuendused, NAVI 2023-24, VIM, SpeedCam,
TarmoValk
postitati 03.03.18 22:43
Mul oli kütuselati survereglaatori teema, masin ei surnud välja. Teema ka selles et 3000 rpm ja oligi jõud kadunud, ning tuluke vilkus. Polnud vahet
kas meelitada või pähe anda, vilkuma võttis igal juhul.
Oli, on ja jääb - Audi
postitati 04.03.18 08:12
N290 pumbas ja lati rõhuregulaator on kaks erinevat asja. Lihtsalt et asi selgem oleks teemaalgatajale.
TarmoValk
