Pealkiri: C4 1,9TDI veakoodidele lahendust tuvastada (Vastuseid: 1 | Vaatamisi: 1532)
Darmo
Registreerunud 26.12.15
Auto: '96 C4 A6 Avant
postitati 21.05.17 13:52 Tsiteeri
Minu 1,9 tdi veakoodid, ehk keegi teadjam mees oskab seletada:
Tuesday,01,October,2013,14:39:19:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Chassis Type: 4A - Audi 100/A6 C4 (1992 > 1997)
Scan: 01 02 03 08 15 17 25 35
Address 01: Engine Labels: 028-906-021-AHU.lbl
Part No: 028 906 021 J
Component: 1,9l R4 EDC SG D16
Coding: 00000
Shop #: WSC 00000
VCID: 162320DA722790AE5EF-4A88
4 Faults Found:
00527 - Intake Manifold Temperature Sensor (G72)
30-00 - Open or Short to Plus
00741 - Brake Pedal Monitoring
27-10 - Implausible Signal - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
Part No: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Shop #: BB 37402
VCID: 2F6DF53EEDBD41663D9-515E
No fault code found.
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 B
Component: Airbag V AUDI D00
Coding: 00766
Shop #: WSC 02324
VCID: 326BFC4AFE8F6C8E527-5198
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01025 - Trigger for On Board Diagnostic Lamp; Malfunction
31-10 - Open or Short to Ground - Intermittent
Address 17: Instruments Labels: 4Ax-919-03x-17.lbl
Part No: 4A1 919 033 HG
Component: C4-KOMBIINSTRUMENT D20
Coding: 00040
Shop #: WSC 00012
VCID: 6ED3283A2A37086E76F-1E0C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 25: Immobilizer Labels: 4A0-953-234.lbl
Part No: 4A0 953 234 F
Component: IMMO AUZ9Z0T0643261 D77
Coding: 00000
Shop #: WSC 42412
VCID: 25411716BF410B36C75-517A
End ---------------------------------------------------------------------
roltskar
Registreerunud 29.05.14
Auto: A4 B8 3.0tdi Q
postitati 22.05.17 19:46 Tsiteeri
Algselt postitas: Darmo
Ma vaatan,et sul neid vigu ikka on seal, sa peaks lisaks veakoodide lugemisele vaatama ka meas. blokke ja hakkama niimoodi näitudele vastavalt vaikselt harutama.
Küsin kohe ära,et kuidas sul akuga ja laadimisega lood on? Sul hetkel sellised naljakad vead,et võib vabalt olla,et lihtsalt pinge on liiga madal ja ajab sellepärast kõik plokid lolliks masinal. Ehk siis lükka multimeeter ka autole külge.
Need on esimesed lihtsamad sammud, mida saad teha, ilma, et peaksid ulme diagnostik olema.
VEkoodide võimalikke põhjuseid ja ka lahendusi saad ross tech'i wikist, kui lööd sisse oma veakoodi. sellest on ka vahel abi.
AvE's 3 rules of troubleshooting: 1. Look for/Do the easiest thing first. 2. Don't rely on the people that tried and failed before you (usalda, aga kontrolli) 3. 90% of problems are between the driver's seat and the steering wheel
[PHP: 57.2% - SQL: 42.8%]
