Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Sigari esiklaasi vahetus
Pealkiri: Sigari esiklaasi vahetus (Vastuseid: 18 | Vaatamisi: 2777)
Jürgen
Registreerunud 11.11.04
postitati 06.04.05 15:37 Tsiteeri
Niisiis oli muidu plaan lasta vahetada, aga kuna igast spetsialiste, kes ise on teinud, on välja ilmund, siis huvitaks just, et kas keegi nimelt audi 100 c3 (82-87) kere klaasi on vahetanud ja oskab ehk õpetussõnu jagada..
kasutatud klaas olemas teise kere peal, vaja eest võtta mõlemal masinal ja kasutatu enda masinale ymber visata...
Mahavõtmise kohta olen kuulnd nii trossi kui ka rauasaega võtmise teooriat (st. nii on ka reaalselt tehtud). Paigalduse koha pealt ainult keegi mainis SR.org's et jõle nu** pidi olema selle kerega masinal... aga ei täpsustand...
Demis
Auto: 5 cyl 20V
postitati 06.04.05 15:54 Tsiteeri
Olin ka ise paari aasta eest sama probleemiga silmitsi. Asjatundjad rääkisid, et see töö on mõtetu, kuna sigaril on klaas liimitud ja selle tervena kättesaamise tõenäosus on nullilähedane.
Renks
Registreerunud 07.09.04
postitati 06.04.05 15:58 Tsiteeri
Vana klaasi tervelt kätte saamine on palju suurem n*** kui uue paigaldamine.Aga tervelt saab kätte küll kui väga vaja.
Jürgen
postitati 06.04.05 16:27 Tsiteeri
tõenäosus koefitsient mind ei hirmuta :P
chat's siiski mind peaaegu veendi, et ehk on mõtekam töökotta minna... aga eks ma vaatan, kui igav mul on :P
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 06.04.05 18:09 Tsiteeri
Paigaldamise juures kõige suurem probleem on vana klaasi eest võtmine. Mina vahetasin möödunud suvel ja klaasikilde ilmus välja veel praegugi. Muidugi kui trossiga eest lõigata siis seda häda vist väga pole. Ja kui teise auto küljest klaasi võtad siis pole liistuga ka jamamist, selle jätad koos osaga vanast liimist klaasi külge.
Tige Kala
Registreerunud 18.01.04
Auto: B7 S-Line
postitati 06.04.05 19:40 Tsiteeri
Osta uus klaas ja lase töökojas vahetada,kulub endal närvirakke vähem ja eeldatavasti ka tulemus parem.
Miks??? Sest...
Vana klaasi kätte saamine on üks ilge n**ss. Rauasae lehe võid ära unustada, sest seda sa liimi vahele ei lükka. Trossiga on selline lugu, et peab olema piisavalt pikk tera sellel otsas, sest alt servast on klaas laialt liimitud. Samal põhjusel ei saa ka "vaibanuga" kasutada. Kõige parem selleks tööks on spetsaiilse klaasisae kasutamine.
Enda V8-l (sama klaas on 100/200/v8) vahetasin nii, et lihtsalt lõin vana klaasi tükkideks ja lõikasin ääred vaibanoaga küljest ära. Tekstiilsisuga autodele seda ei soovita, sest pärast väga raske autot klaasikildudest puhtaks saada. Liimimisel tuleb pinnad puhastada spets ainega + aktivaator + liim.
Uus klaas maksab ca 1300-1500 krooni ja klaasiliiimi tuup ca 170 eequ, kui kedagi peaks huvitama.
Renks
postitati 06.04.05 19:54 Tsiteeri
Mis tähendab piisavalt pikk tera trossi otsas- tross on tross ja tera on tera, need on kaks täiesti erinevat asja.
pikkpresident
Registreerunud 30.07.05
Auto: Audi 100 "sigar", UAZ 469
postitati 06.08.05 11:09 Tsiteeri
Sigar tõesti üks hullemaid autosid ses suhtes:( Väga ettevaatlik peab olema ka selle liistuga, maksab teine suurusjärgus 1keek. Ise lasin asja teha ühes kenas kohas Põlvas, kus asi läks 1000(klaas)+650(töö), odavaim variant, mis Lõunaosariikidest leidsin. Teistele autodele pidi seal 500 eest tehtama... Kuidas eest võeti, ei tea, ilmselt tehnoloogia a la "suure saapaga aknasse":D
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 06.08.05 11:38 Tsiteeri
Soovitaks Autoklaasi minna - seal tehakse korralikku tööd.
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 06.08.05 15:20 Tsiteeri
Olen ise vahetanud sigaril absoluutselt kõik klaasid ja trossi kasutamise puhul tuleb osta kohe kõik uued liistud.
Ainus normaalne variant on kasutada spetsiaalset klaasinuga,kas siis suruõhu või elektriga toimivat.
Sellega on võimalik esiklaas ja ka tagaklaas kätte saada,kuid ka siis tuleb kombineerida mitmete erikujuliste teradega.Ja siis jäävad ka liistud ja kummitihendid terveks.
genekas
postitati 06.08.05 17:17 Tsiteeri
Autoklaasis suutsid igatahes sigaril välimise liistu uue klaasiga tagasi panna...
QUATTRO
postitati 06.08.05 17:29 Tsiteeri
Seda ma üritangi siin tõestada.Et liist tervelt kätte saada ongi aint kaks võimalust.
Kas lööd klaasi sisse ja lõikad siis jäägid maha või kasutad selleks tööks ettenähtud tööriistu.
Autorehvi on võimalik ka vahetada metallvinklite ja 8 kilose haamriga aga velje ja rehvi väärtused peale seda on kaheldavad.
Ja kui see iseliimitud ja jebitud klaas peaks hakkama kuskilt hiljem läbi lekkima,siis on nigunii minek klaasiteenindusse.Kuna juba see omab tähtsust kuidas,kuhu,mis kujuga ja kui paksult on klaasiliim paigaldatud.
genekas
postitati 07.08.05 09:55 Tsiteeri
Algselt postitas: QUATTRO
Kusjuures Autoklaasis saadi klaas tervelt eest ära - nägin mahavõetud klaasi eemal prügihunnikus...
QUATTRO
postitati 07.08.05 10:08 Tsiteeri
Seda ma ju silmas pidasingi.
audi4ever
Registreerunud 17.05.05
Auto: Audi
postitati 29.09.06 15:35 Tsiteeri
Endal ongi probleem,sigari klaasi tihend läks väga kõveraks!Milline tihend sinna esiklaasile sobiks?Kas mingi universaal või siis esindusest saab midagi?
NegativeExperience
Registreerunud 07.09.06
Auto: a4 Avant 2,5 TDI
postitati 29.09.06 19:29 Tsiteeri
juudi vanasõna ütleb ,et "ainus võimalus klaas tervelt kätte saada on see puruks lüüa"
Stupidity is not a handicap!
Park elsewhere!
ferdinand
Auto: 400,401,969
postitati 29.09.06 19:37 Tsiteeri
Algselt postitas: audi4ever
Klaasimüüjad pakuvad plekkliistu hinnaga u 700.- ja mingisugust kummist asendusliistu kusagil u 300.- eest.
ullivilli
Registreerunud 18.05.07
Auto: C4A 2,5TDIQ, BMW GS1100
postitati 07.09.07 14:43 Tsiteeri
Tõstan vana tema üles, kuna ei näe mõtet uut teha.
Palju võiks praegusel ajal sigari esilaas+vahetus maksma minna?
Ja kus seda tehtaks?
Minge metsa!
www.minemetsa.ee / www.ripptelk.ee
Kaits
Registreerunud 01.03.03
Auto: RS 6 Avant
postitati 07.09.07 15:21 Tsiteeri
http://www.klaasiteenindus.ee/
Sigaril jätavad ka vana liistu terveks ja panevad tagasi. Väikese lisatasu eest.
Soovitan.
[Päringuid: 23]
[PHP: 0.7% - SQL: 99.3%]
