Lehekülgi: 1 .. 42 43 44 45 46 .. 61 |
arro
Registreerunud 10.11.06
Auto: C3 quattro, C4 quattro
postitati 31.08.12 10:45
Anti lag system on selle nimetus, ning kasutati seda siis S1 peal
Väike seletus töö põhimõttest siin:
When off throttle the 2nd wastegate would open by being triggered off the Vacuum pressure on the backside of the throttle body. Thus, oxygen rich
charge air could enter the exhaust manifold and intermingle with the fuel rich exhaust which would be suddenly rich due to the throttle close. This
would burn in the exhaust manifold. Which would run the turbo more which would run more air through the exhaust, etc etc. Pretty much a system that
feeds on itself until it reaches some happy rate of Rage which is probably at the upper operating limit of the turbocharger. The minute you crack the
Throttle back open the 2nd wastegate would shut and all that charge air which was whizzing through the exhaust system would now be blasting through
the engine. So it pretty much ran the manifold like a turbojet. I'm sure the crazyfast computers of the day, couldn't keep up with the system and it
ran itself into puddles of molten metal. Bruno used it and said it produced 1.5 bar of boost at idle and had instant power with no lag. It was very
hard on the exhaust valves as it produced very high exhaust pressures and temperatures.
postitati 31.08.12 12:27
Antsu leidis õige koha ja selgitas veidike, arro selgitas juba korralikult. Kumb teist kiirem on esitab järgmise küsimuse.
antsu
postitati 31.08.12 12:41
Arro las esitab. Mul pole ühtegi varukast võtta hetkel.
arro
postitati 31.08.12 12:42
Millal kasutas Audi esimest korda Bosch Motronic EFI süsteemi 10VT mootoril? Ja mis autoga oli tegu?
antsu
postitati 31.08.12 12:54
Audi Quattro A2 versioonil? 1980 midagi
NOS
Registreerunud 04.05.09
postitati 31.08.12 13:13
Audi 100, 1990?
postitati 31.08.12 14:51
Pakun 1984 Audi GT Coupe.
arro
postitati 03.09.12 06:05
Päris õigeid vastuseid pole, aga kahepeale antsu ja Kuits saavad vastuse kokku
Tegemist oli siis jah Audi Coupe quattro A2´ga ning oli kasutusel enne 20V mootori kasutusele võttul 1984 aastal.
Järgmine küsimus, otsustage ise kumb esitab!
EDIT: Lisan ka ühe pildi sellest.
http://www.bufkinengineering.com/L-DG83-11.jpg
antsu
postitati 03.09.12 09:08
Zoigil on õigus. Audi Quattroga A2 on nimetus ka minuteada. Minul küsimusi ei ole. Keegi teine võib tuld anda.
Amadeuz
Registreerunud 09.03.05
Auto: C5 avant TQAT 110 kW õlipress '99 (Nora), MB W639 kombi AT CRD 80kW (Jasmin)
postitati 03.09.12 10:29
Kuna keegi ei taha küsida, siis pakuks vahelduse mõttes ühe lihtsa küsimuse.
Mis autoga on tegu. Mis aastal tehtud ning mis firma on kere taga?
http://www.hot.ee/amadeuz/img/Audi_X.jpg
_________________
www.andmebaas.ee
tarmo
Registreerunud 05.01.03
postitati 03.09.12 10:33
Pininfarina Quatrz, ehitati 1980, esitleti 1981 Genfi automessil, põhjaks Quattro.
Amadeuz
postitati 03.09.12 10:45
See läks küll kähku. Anna uus küsimus nüüd sama kiirelt ;P
_________________
www.andmebaas.ee
tarmo
postitati 03.09.12 10:48
Jätkame samal teemal. Kes selle auto ära ostis?
indro
Registreerunud 25.09.02
postitati 03.09.12 11:00
Tsitaat: | Algselt postitas: tarmo
Jätkame samal teemal. Kes selle auto ära ostis? |
Hetkel paistab see auto Saksamaal Audi muuseumis asuvat, Audi ostis?
tarmo
postitati 03.09.12 11:21
Just, tuld.
Raadik88
Registreerunud 28.05.09
Auto: Audi A3 2.0 TDI 125kw müüdud. Audi B4 85kw - müüdud.
postitati 04.09.12 07:44
Nii kaua kui indro mõtleb, küsin ühe lihtsa küsimuse.
Uus a8, mitu nõelapistet kulub nahksisu valmistamiseks?
ee-martynas
Registreerunud 19.08.09
Auto: A6 2013 3.0 TDI
postitati 04.09.12 08:01
Tsitaat: | Algselt postitas: Raadik88
Uus a8, mitu nõelapistet kulub nahksisu valmistamiseks? |
Vabandust lolli küsimuse pärast kuid kas sellele küsimusele vastamiseks on eeldus uue A8 omamine?
Raadik88
postitati 04.09.12 08:48
Tsitaat: | Algselt postitas: ee-martynas
Vabandust lolli küsimuse pärast kuid kas sellele küsimusele vastamiseks on eeldus uue A8 omamine? |
Ei.
veekaheksa
Registreerunud 07.09.03
Auto: S6 PLUS 4.2, A4 TDI quattro
postitati 04.09.12 10:22
1600?
PLUS TDI Die Menschen sollten nicht
schlafen, während sie unterwegs sind, aber sie tun es trotzdem.
Fugitive
Registreerunud 12.02.06
postitati 04.09.12 10:48
36520
Raadik88
postitati 04.09.12 13:05
Tsitaat: | Algselt postitas: Fugitive
36520 |
Õige.
Fugitive
postitati 04.09.12 13:37
Mitu erinevat Audi mudelit on tänaseks osalenud DTM'is. Mis mudelitega on tegemist?
jokerAudi
Registreerunud 09.02.08
Auto: Superb 2018
postitati 04.09.12 13:56
Mitu erinevat Audi mudelit on tänaseks osalenud DTM'is. Mis mudelitega on tegemist? |
4 mudelit vast? V8, A4, TT, A5?
Fugitive
postitati 04.09.12 14:23
Jep!
