Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Autocheck ja tuled.
Pealkiri: Autocheck ja tuled. (Vastuseid: 34 | Vaatamisi: 6491)
lynx
Registreerunud 15.10.02
Auto: Audi
postitati 08.02.05 16:46 Tsiteeri
Autocheck ja tuled.
õhtust,
Ära kallale tulge, kui teema väga aktuaalne juba kusagil olnud on - ei näinud!
Asi selles . . . peale xenoni paigaldus arvab autocheck pidevalt, et tuled ei põle ja see pinin hakkab juba päris ajudele. Arvatavasti tavalise halogeen pirni ja kõrgepinge bloki takistused ei ole samad, ning autocheck nii tark nagu ta on, arvab et nüüd tuled ei põle.
Any ideas, kuidas sellest lahti saada? Kasvõi see featuur kuidagi välja lülitada?
tänud ette :)
Silwer
Registreerunud 11.12.02
postitati 08.02.05 17:19 Tsiteeri
Minu autol seda probleemi ei ole.
BMW 325i E30 2,8 stroker & BMW 328iT E36 & Seat Altea XL 2,0 TDI+DSG
samru
Registreerunud 01.02.04
postitati 08.02.05 18:45 Tsiteeri
Algselt postitas: lynx
õhtust,
tänud ette :)
See jama on tingitud sellest, et xenonid tarbivad oluliselt vähem voolu ning tulede kontrollmoodul arvab, et pirniga miski jama. Kõrvaldada saab seda viga nii, et otsid selle mooduli ülesse (kuskil juhi pool releede juures - täpselt ei tea kuna olen seda teinud ainult C4 kerega Audidel) ning võtad selle ploki pesast välja ja painutad ühe jala (vist nr.9) kõveraks, noh, et ei annaks ühendust autotsekile. Proovi ehk aitab.
lynx
Auto: Audi
postitati 21.02.05 11:42 Tsiteeri
relee nr. 281 ja jalg K tuli kõrvale väänata.
Silwerile niipalju, et Sul on arvatavasti lisa releed vahel, sellepärast. Kuid idee järele ei ole mingit vahet, st. kui Sul pirn peaks läbi põlema siis autocheck ei tohiks Sul ikkagi midagi näitada, kuna relee tarbib voolu ikkagi edasi.
vot nii :)
postitati 21.02.05 11:57 Tsiteeri
Oli siis kasu ka? Minul läks autocheck hulluks pärast seda, kui tuledele releed vahele panin. Algul tegi iga täistuledelt pooltuledele ümberlülitusega piiksu, pärast kontrollrelee 301 mingi jala (ka vist K?) väänamist teeb piiksu ainult pärast käivitamist ja displeil vilgutab kogu sõidu aja läbipõlenud pirni ikooni. Suht närvidelekäiv.
lynx
Auto: Audi
postitati 21.02.05 12:12 Tsiteeri
Algselt postitas: Black
Oli siis kasu ka? Minul läks autocheck hulluks pärast seda, kui tulede releed vahele panin. Algul tegi iga täistuledelt pooltuledele ümberlülitusega piiksu, pärast kontrollrelee 301 mingi jala (ka vist K?) teeb piiksu ainult pärast käivitamist ja displeil vilgutab kogu sõidu aja läbipõlenud pirni ikooni. Suht närvidelekäiv.
Hmm, mul (lisa)releesid vahel ei ole.
Ma hetk tagasi väänasin selle jala alles ära ja oskan õhtul täpsemalt öelda, mis ja kuidas. Kuid esimesed 5min kui proovisin, autocheck oli ilusti vait - thank god - jääks see ainult nii. Autocheki "check" tehes, on kõik ok.
lynx
Auto: Audi
postitati 22.02.05 18:04 Tsiteeri
oli kasu :) imelik on kohe vaikuses sõita :D st. ilma selle pininata.
Sniper
Registreerunud 26.09.04
postitati 27.09.05 07:06 Tsiteeri
Tõstan vana teema ülesse kuna pealkiri on mulle sobiv;)
Siin on küll juttu esitulede vea ikoonist, kuid mind huvitab piduri tulega seonduv ikoon, ehk siis "brake light", mis ei taha kuidagi ära kustuda.
Olen üle vaadanud kõik juhtmed/ühendused/pirnid mis seonduvad piduri tuledega kuid mõistus enam peale ei hakka.Kusjuures piduri tuled põlevad täiesti normaalselt.Ainuke asi mida veel ei ole teinud, on testriga ära mõõta pirni pesadesse tulev vool.
Kas kellegil on selles osas kogemusi, kuidas seda asja korda saada?
Niipalju veel lisaks, et lisa pidurituld pandud ei ole ja samuti ei ole järelkäru pistikut.Ehk siis midagi ise aretatud ei ole.
Ette tänades,
Andres
jan-kos
Registreerunud 23.04.03
postitati 27.09.05 12:14 Tsiteeri
Mina panin kärupistiku ja lisapidurituli on ka aga piduritule kontroll kustub ära.Kas pirnipesad on ilusti puhtad ja pirnid korralikult pesas?
Sniper
postitati 27.09.05 12:51 Tsiteeri
Algselt postitas: jan-kos
Kontrollitud on nii pesad kui ka pirnid.Pirnid on pandud tegelikult uued, kuna vanad olid juba ära väsinud.
Hardo
Registreerunud 28.02.05
Auto: Audi A6 3,0 TDI S-Line
postitati 27.09.05 13:58 Tsiteeri
vot nii :)
Kus asub relee nr.281?Ja jalg K
jan-kos
postitati 28.09.05 07:29 Tsiteeri
Sniper- siis soovitan veel armatuuri taga olevad pistikud üle vaadata ja kontaktid üle joota plaadil,ma sain nii lahti veast mis andis et üks pirn ei põle.
Sniper
postitati 28.09.05 07:34 Tsiteeri
Tänud.Eks nädalavahetusel hakkan pusima.
lynx
Auto: Audi
postitati 29.09.05 07:47 Tsiteeri
Pole küll kindel, kuid kui tegu on autocheckiga siis seal taga ei ole küll mingit pirni, vaid tabloo. Jootmine sellisel juhul küll midagi juurde ei anna.
Kusjuures mul enda audiga hetkel sama probleem . . . ok, ok . . . autol üks tagumine tuli ei ole ka enam elu - ja tervise juures ning arvatavasti lühised seal taga, kuid see brake light ei kustu kui pidurit vajutada. Minu autol kindlasti probleem lühises, kahjuks ei tea kas pidurdades pidurituli ka põleb, kuid pirn on terve kindlasti.
O.T xenonite kohta.
Eelmisel nädalal sai 3 komplekti paigaldatud: A3. bemmi E39 ja aasta vana Almera.
Audil on sügavalt savi et teised tuled ette sai, kompu lisainfot pole veel kuvanud.
Almeraga sama lugu.
Bemmiga natukene teistmoodi, parkide peale lülitades ütleb et tuled ei ole korras, xenonid sisse lülitades kaob see veateade. Võimalik, et kontrollib tulesid kohe kui süüde sisse lülitada ja ei saa piisavalt infot, samas kui tuled põlevad, saab.
postitati 29.09.05 15:26 Tsiteeri
Ta vast mõtles seda, et armatuuris asju üle jootes sai lahti läbipõlenud pirni veateatest.
BTW, autochecki tabloo taga on ka tegelikult 2 pirni.
Kuigi ma olen 10x armatuuri lahti võtnud ja kõiki ühendusi seal kontrollinud ja sama teinud ka tulede juures, põleb mul ka see "brake lights" pidevalt autochekis. :( Pirnid ja pesad on nagu uued ja täpselt õige tugevusega, lisatulesid ega haakekonksu pole.
jan-kos
postitati 30.09.05 07:35 Tsiteeri
Tõstan veel korra üles seda teemat.Ma mõtlesin jah seda, et annab vea teate- "pirn läbi"(pirn ja rist peal).Katseeksitus meetodil jäi veel meelde,kui avastasin armatuuri taga asuva ümber seadmise lüliti ja seda ümber lülitades mingisse asendisse andis pidevalt sümboli "kütuse lõppemine" kuigi kütust oli.Vahest peitub seal mingi nõks.
ve1ks
Registreerunud 23.02.04
Auto: B4 Avant 2,6 V6
postitati 30.09.05 15:18 Tsiteeri
Mul pirni viga näitab samuti, seadistasin ümber ja asi ei muutunud, olen jootnud ka plaadi üle- ikka ei midagi. Tuled kõik korras, krt ei oska otsida enam. :( Jama sai alguse jäärajal ja enam lahti ei saa.
ve1ks
postitati 12.11.05 12:11 Tsiteeri
Uuesti aktuaalne teema.
Lappasin täna pool päeva armatuuri all C4-l ja ainulke asi mis jäi leidamata oli Autochecki juhtmoodul. Otsisin juhi jalgade kõrvalt seinalt plastiku ja armatuuri alt, sama ka teiselt poolt ja mida ei leia seda ei leia.
postitati 12.11.05 21:30 Tsiteeri
Algselt postitas: ve1ks
Otsi kojameeste alt releekarbist. Selline pikergune on.
ve1ks
postitati 13.11.05 07:33 Tsiteeri
Kui sa pead silmas seda karpi mis on kapoti all soojenduse kõrval, siis sealt kakkusin ka selle relee välja ja miskit ei muutunud ja klemmi tähega K ei leidnud ka selle relee pealt.
samru
postitati 13.11.05 08:37 Tsiteeri
Selle "relee" väljavõtmine ei aitagi (siis ei põle tuled kah) vaid tuleb kõrvale painutada see klemm, mis annab kompuutrile signaali, et pirn on läbi. Kui sul tegelikult on kõik pirnid õiged/korras ja ta lihtsalt annab sulle märku, et pirn on läbi on viga mujal (kellade blokis).
ve1ks
postitati 13.11.05 13:14 Tsiteeri
Pirnid on õiged, et nagu ma aru saan peaks see relee olema siis tulede relee, mis annab pinge muutustest märku Autochecki?, parandage mind kui puusse panin. Kuid kas siis see klemm on märgitud lihtsalt tähega K või on seal juures veel sümboleid.
Kellade plokist vea leidmine vist suht keerukas saab olema, kas peaksin siis uuesti üle jootma need otsad klemmplaadilt?
samru
postitati 13.11.05 13:30 Tsiteeri
Sellepärast panigi sõna relee jutumärkidesse, et seal pole releega mingit pistmist. See on elektrooniline kontrollseade, mis tõesti mõõdab lampide voolu tarbimist ja kõrvalekalde puhul annab signaali autotsekki. Klemmi K ei ole mina välja käinud, see käib vist B4 kohta. Kui viitsid võid need peenemad klemmid üles loetleda äkki tuleb mulle meelde. Skeemi järgi vaadates peaksid olema klemm nr 9 või 3 kirjas releebloki pesa peal, üks neist on piduritule klemm.
ve1ks
postitati 13.11.05 16:17 Tsiteeri
58L/56bR1/58R1/KS/Kb
58L1/56bR/56bL/54L/54/31
/56bL1/58R/54R/15
Selline on tulede mooduli klemmide nummerdus minul.
/ - klemmide vahe
samru
postitati 13.11.05 17:00 Tsiteeri
/56bL1/58R/54R/15
/ - klemmide vahe
Kb - peaks olema piduritulede kontroll
KS - peaks see õige asi olema
[PHP: 15.4% - SQL: 84.6%]
