Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi S4 - 1999 - badman
 Lehekülgi:  1  2  3  4
Pealkiri: Audi S4 - 1999 - badman (Vastuseid: 79 | Vaatamisi: 73519)
badman
Registreerunud 07.10.08
Auto: a4 30v Q; s4 1999; 90 coupe 20v
postitati 21.06.10 20:33 Tsiteeri
Diagnoos pandigi et klapp/klapid vigased (üldjuhul), küsimus aga hoopis see, et kas sõitmine tuleks sootuks lõpetada või võib normaalkiirustel liigelda ilma tagajärgedeta. Samas, kui oleksin natukese rahulikuma jalaga liikleja, siis poleks ju viga avastanudki?
badman
postitati 13.07.10 18:50 Tsiteeri
Sai Hiljuti jälle kord rem. töökoda külastatud. Ikka on probleemiks kõikuv rõhk. Avastati, et karterituulutuse voolik oli üks katki ja see asendati hetkel ajutise lahendusega ja homme saab õige detaili külge. See seletaks natukese tühipöörete kõikumist ja selle vähenemist peale toru rem. Mis aga välja tuli, oli see, et wg. klapid on korras ikkagi ja probleemiks jällegi nüüd by-passid. Esialgu:D:D:D Siit ka pisike küsimus? Mis vahe on audi tt ja 2.7 BiT by-pass klapil, et seda soovitatakse siin ja seal asenduseks ja mis need maksaksid? Kui hind on oluliselt odavam kui nt forge omad, siis laseksin homme need kah kohe külge panna uutena ja saaks ükskord selgusele, mis krdi kala seal kapoti all on! :mad:
badman
postitati 14.07.10 15:19 Tsiteeri
Sain siis auto jälle kätte ja lekkivad by-passid said vahetatud TT omade vastu. (hetkel). Kuna kihutada enam eriti ei soovi nii aastakese :D , siis proovisin ainult 3 käiguga gaas põhja ja minema ja ikkagi katkub rõhu maha. Tõsi hetkel hoiab seda natukese kauem, kui teiste klappidega, aga siiski. Proovin täna teha ühe klip kah, et oleks arusaadav, mida ma silmas pean. Ahjaa kui pedaali just päris läbi põranda ei vajuta, siis rõhk nagu hoiaks ennast, aga nii kui muljusin kooralikult edasi, siis kohe kukkus.
Lisaks tekkis küsimus, kuhu kohta ja mille vahele ma saaksin paigutada oil-catch vidina. Tuli meelde, et selline asi koliseb juba pikalt pakiruumis.?
badman
postitati 14.07.10 18:40 Tsiteeri
Tegin siis klipid ära ja panin ülesse. Jään ootama arvamusi ja soovitusi. Minu mõistus on otsas kuna vigu kaabel ei näita ja lekkeid enam kah ei ole. http://www.youtube.com/watch?v=ypUXNKPxYEo http://www.youtube.com/watch?v=woeYrmmEe6k http://www.youtube.com/watch?v=_0YFCQQ_IAU
rmm
Registreerunud 14.02.05
Auto: S4
postitati 15.07.10 18:12 Tsiteeri
Kui kell ei valeta ja tõhk tõesti 1.7 bari tuleb, siis vajab N75 ilmselt vahetamist.
badman
postitati 15.07.10 19:14 Tsiteeri
Kusjuures seda et 1.7 bar puhus avastasin ise alles klippi vaadates. Varasemalt pole seda näinud. Korra varem puhus kella skaalalt välja (2.0 bar) ja hakkas paugutama, aga siis sai renoveeritud õhulugeja vahetusega sellest jagu.
MartinCS
Registreerunud 28.03.06
postitati 15.07.10 22:18 Tsiteeri
Algselt postitas: badman
Kas see kell ise kuidagi villast ei saa panna? Või kellavoolik sõlmes vms?? Kuidagi kole kärmelt hüpleb see rõhk. Auto rahvast täis kuuma ilmaga nägin isegi 1,4 bari kella järgi ülerõhku.
basssoundman
Registreerunud 17.09.07
Auto: 3x RS4
postitati 16.07.10 05:13 Tsiteeri
Mina soovitaks kontrollida ka rõhu lekkeid (mida ilmselt on ka tehtud?) ja seda just nt turbode kompressori pooltelt tulevaid kontroll boosti metalltorusid, mis kipuvad õige natukene murduma turbo enda juurest ja lekivad (kontrollrõhk ei ühti tegeliku rõhuga ja ajab auto lolliks = boos kõigub ja teeb overboosti = fuelcut jne). Kahjuks on leke nii väike, et seda ei pruugi märgata ja kuulda ilma süvenemata ja probleem on ilmne. Oli endal samalaadne jama. Kokku saavad parema ja vasaku turbo torud enne N75 klappi. Vahetada neid torusid ilma motot maha võtmata väga ei saa, kuid taaskord aitab hydroscand spets liitmiku ja kuumakindla voolikuga.
Õige oleks teha nii, et peale intake Y toru ühele pime ette ja teisest poolest survestada (gaasiklapi ees jaotub surve võrdselt mõlemale poolele). Mingi 1,5bar võiks enamvähem ilusti ikka hoida stock konditsioonis.
Teiseks variandiks pakuks by-pass klappe, kui aga need on vahetatud, siis ilmselt ei tohiks selles asi olla.
Kolmandaks soovitaks proovida mõne töötava auto pealt N75 klappi vahetuseks.
Neljandaks võiks kontrollida ka veel kõik pisikesed ja suuremad vaakum ja surve voolikud üle, mida antud autol on kapoti all kilodega. Väike leke kuumusest hapraks muutunud vooliku näol = palju peavalu.
www.bsm.ee Innovatiivsed helilahendused
badman
postitati 16.07.10 06:33 Tsiteeri
Algselt postitas: MartinCS
Kella voolik ei ole sõlmes ja rõhu hüppamine on kiirendades korralikult ikkagi tunda. Tunne selline nagu mängiks gaasipedaaliga, seega usun, et kell ei valeta. Ja auto enda tõmme pidavat suhteliselt "meeldiv" olema "jõuvankri" proovimise põhjal. Kuskilt 3000 rpm pealt. Ise kahjuks ei tea kedagi teist kellel oleks korras S4 ja puudub info mis chicp autole pandud on jne.
badman
postitati 16.07.10 06:41 Tsiteeri
Algselt postitas: basssoundman
Äkki oskad/leiad aega natukese juhendada/näpuga näidata täpsemalt. Vabandused, olen küll olnud ja õppinud rem.mees, aga kogemused Audidega puuduvad, lisaks nii vähe ruumi, et ma ei oska kuskilt pihtagi hakata.
badman
postitati 20.07.10 08:59 Tsiteeri
Auto ei ole enam minu kasutuses ja müüdud ta ongi. Kahju oli, kuid vahets ehk antakse ikka, kui vaja peaks olema.
badman
postitati 02.09.10 22:56 Tsiteeri
Kas keegi softiga ka tegeleb? Sain infot, et mu vana S võis jukerdada liiga "kange" chipi pärast, mis võis olla tehtud just kiirendamiseks. Jutt võib kõlada lollilt, aga nii mulle räägiti eelmise omaniku poolt. Ehk siis igasugused saksa chipid on jama ja autol peal autohai kangeim chip, võimaliku miski lisandiga just 400 m jaoks eeskätt (tema sõnad). Et kuna ma endiselt selle autoga ka edaspidi aegajalt tegelen ja kiman, siis oleks hea, et saaksin viimasegi vea likvideerida ja kuidagi normaalselt ka alates 4. käigust tööle saada. Ootaks siis arvamusi ja ettepanekuid. a la lahjem chip, kus, kes ja kas.
Tänud
Dan
Registreerunud 05.11.03
Auto: VW Golf R Mk7; Audi A3 SB quattro, Audi 80 quattro
postitati 03.09.10 07:36 Tsiteeri
Vabandust aga see jutt mitte ainult ei kõla lollilt.
Sellel autol on täpselt sama chip nagu minul aga minu autol sellised probleemid puuduvad. See muidugi ei välista vigast aju/chippi aga kaldun siiski arvama, et põhjus kusagil mujal.
postitati 03.09.10 08:02 Tsiteeri
100% jama.
badman
postitati 03.09.10 22:52 Tsiteeri
Tänud. Sain kinnitust sellele, mida isegi arvasin, et tegu jama jutuga, kuid kinnitust pidin saama, et välistada muud jama. Seega lähitulevikus (kuna auto hetkel liikleb vaid u 100 km nädalas ja rahulikult) tuleb lasta teha nö. pikk rõhu- ja survekontroll ja siis edasi saagat jätkata. Kui kellelgi on soovitusi või midagi muud, siis olen suur kõrv.
Maku
postitati 04.09.10 08:33 Tsiteeri
Pmst sama jutt nagu kunagi Olku ja Vaniko RS2-tedega. Üks sõidab teisest oluliselt kiiremini, olgugi, et softid on samad.
badman
postitati 08.10.10 19:14 Tsiteeri
Auto siis külastas jälle töökoda. Probleemid ikka samad. Avastati pisikene rõhuleke, mis sai ka kohe likvideeritud, kontrolliti süütesüsteemi, vahetati välja 6 piipu/pooli ja tulemus ikka sama, nagu varem. Niipalju sain targemaks, et asi kaldub siiski softi poole. Peab leidma mooduse kuidas taastada originaalseaded või panna lahjem chipp, mis hoiaks rõhud paigas. Nii kui auto oli end soojaks sõitnud, hakkas uuesti tekkima probleem rõhu saavutamisega. esimene kord kiirendades kisub 1.5 bar (mida on muidugi originaal turbote jaoks palju, ja sealt ka see softi teema), kuid järgmine tõmme juba üle 0,5 bar ei lähe. Ootad u 10 mintsa ja sama asi kordub. Kas on nüüd max 6000 km sõitnud bypassid jälle saba andunud või hakkab auto puhta lolliks minema. Vihaseks juba ajab. Äkki saab uuel nädalal pea sappa visatud ja klapid kontrollitud. Kuidas saaks taastada softi, kui nö backup file puudub? Või on kellelgi miskit aju laenata, et saaks veenduda probleemi olemuses?
ICE
ac aasta auto 2006 võitja
Registreerunud 27.09.02
postitati 08.10.10 20:36 Tsiteeri
Muideks need "eelmised" täiesti korras, töötavad laitmatult. Siis ka ise ei teadnud, kuidas õigesti testida neid. Nüüd targem :)
Aga loodetavasti saad oma mured lahendatud.
MartinCS
postitati 08.10.10 20:57 Tsiteeri
Õhulugeja?
Ega veojõukontrolli tuli ei põle?
Kusjuures vigase lugejaga kohe safe-mode ei läinud vaid lasi mingi 1,1bari üle veel pool päeva???
Peale õhulugeja vahetust käitus auto eriti veidralt. Kõigepealt sõitis nagu oleks ikka õhulugeja vigane... ehk 0,5 bar oligi maks, kuigi kõik vead said ajust kustutatud jne. Siis ei tahtnud üle 1,0 bari puhuda. Pauguta palju tahad ei lähe.. .siis mõni aeg hiljem hakkas järsku viskama mingite pöörete juures..1,5..siis kuni 1.0 siis jälle järsku üles. Põhjagaasiga pendeldas boosti seier siia-sinna. Lõpuks muutus stabiilseks ja puhub maks 1,2...1,3...äärmisel juhul 1,4 üle. Aga see oli ka 50 km kuuma andmist umbes.
badman
postitati 09.10.10 02:44 Tsiteeri
Algselt postitas: ICE
Vabandused bypasside probleemi suhtes, kuid diagnoos ei olnud minu pandud.
badman
postitati 09.10.10 02:53 Tsiteeri
Õhulugeja?
Niipalju, kui ma olen lasknud asja uurida, ei ole diagnost vigu näidanud. Õhulugeja viga tuli ilmsiks siis, kui hakkas 2.0 ja rohkem bar puhuma äkitselt. Ja sümptomid muidu olid kah samad nagu sul, kuid seekord vigu ei olnud. Probleem kui selline on vaevanud mind aga aegade algusest alates, e. siis laheduse otsimine kestab alates selle aasta jaanuarist. Veojõukontrolli mul ei ole.ainult miski pidurdusjõukontroll vms (vana 2.8 Q sain gaas ja pidur peal kurvi läbida, kuid sellega gaasi ajal kergelt pidurit puudutades katkub kohe jõu maha). Iseenesest esimene mõte peale seda kui enam rõhku üles ei krivinud oli, et jälle õhulugeja, kuid audihoolduses tõsteti käed üles ja arvatakse kah, et pigem nüüd juba softi viga.
badman
postitati 09.10.10 02:58 Tsiteeri
Üleüldiselt on neid bypasse ja õhulugejaid nii minu kui ka eelmise omaniku juttude põhjal vahetatud ja kordi liiga palju. EGT d kah vahetatud u aasta tagasi ja nende vigu kah ei ole näidanud kordagi. Eile sai veel sõbra juures siva pea sappa visatud (peale mõningast sõitu ja probleemi taastekitust ning mälu puhas kui valge leht.
Põhimõtteliselt pean vist käima kuskil mujal ka korraks diagnistis ja uuringutel ja Tartus tartsi juures, et äkki saab teada mis soft ja kui siis algseaded taastada ja siis edasi uurida. Kui töö aega annab, siis uuel nädalal ka vkm-st läbi põigata.
rmm
Auto: S4
postitati 09.10.10 06:12 Tsiteeri
K03 ja 2bar?
Ma juba kord soovitasin - vaheta N75 ära.
Soft ei pruugi olla kõige parem, aga vaevalt et sinna selline rõhu kõikumine sisse kirjutatud on.
wampiiroja
Registreerunud 09.09.09
postitati 09.10.10 11:45 Tsiteeri
Enda S4 on hetkel sama mure ,et boosti liiga palju lööb kella põhja ehk siis 2 bari. Autol on sama chip millest siin juttu juba oli.
Sai N75 klappi puhastatud peale seda asi läks paremaks aga boost ikka palju jääb hoidma 1.3 bari umbes.
Igal juhul klapp sai tellitud ja jõuab järgmisel nädalal, ja siis saab juba uut infot jagada kas paranes.
audihunt
Registreerunud 12.08.07
Auto: Audi quattro
postitati 09.10.10 12:58 Tsiteeri
Kui palju N75 maksis ? Ja kas ta on identne 2.2T mootoritel kasutatavaga ?
 Lehekülgi:  1  2  3  4
[PHP: 18.8% - SQL: 81.2%]
