 postitati 30.12.10 14:39
Algselt postitas: margus
Oi! See on nüüd küll tore uudist!
Nüüd ehk teeb keegi ka pakkumise järgmistele koodidele:
1. 8D0511247
2. 8D0511523
3. 8D0505171
4. 8A0505172B
5. 8D0505185A
1. 8D0511247
2. 8D0511523
3. 8D0505171
4. 8A0505172B
5. 8D0505185A
Lisaks eelnevale mudrule soovitaks teemaalgatajal uurida ka koheselt ekstsentrikpoltide hinnakirja.
Autoeksperdis sain need 190 eeku 2tk.
Minul oli nende lahti saamisega probleem ja seega soetasin uued.
Margus, vaata ka korraks siia teemasse.
 postitati 30.12.10 14:34
Telefoni ei ole, et poodi helistada ?
margus
 postitati 30.12.10 14:25
1. 8D0511247
2. 8D0511523
3. 8D0505171
4. 8A0505172B
5. 8D0505185A
 postitati 30.12.10 13:58
Mitte ei pääse vagcati sisse, et ise uurida, kuid kas keegi leiab mahti postitada Audi A4 B5 quattro tagasilla joonise siia? Eriti hea kui saaks ka kõikide pukside koodid juurde.
http://www.vagcat.com/p/B123/505300.png
wheel bearing housing / rear
suspension
1 8A0505427G
75MM left /
(1) 8A0505428G
75MM right /
2 8D0505171
bonded rubber mounting
(3) 8D0505323B
track control arm
left upper /
(3) 8D0505324B
track control arm
right upper /
(4) 8D0505185A
inner /
5 8A0505172B
outer /
6 8D0505311
track control arm
left lower /
(6) 8D0505312
track control arm
right lower /
7 8D0511247
front, inner /
8 8D0511523
bearing
rear, inner /
9 8A0512341F
mounting / F >> 8D-V-140 000*
left /
(9) 8D0512341
mounting / F 8D-V-140 001>>*
left /
(9) 8A0512342F
right /
(9) 8D0512342
right /
10 8A0512297E
damping ring
11 8D5511115F
coil spring / 2 paint marks / 1 paint mark
white violet /
(11) 8D5511115G
coil spring / for models with towing facility / 2 paint marks / 2 paint marks
white violet /
(11) 8D5511115G
coil spring / 2 paint marks / 2 paint marks
white violet / AVANT
(11) 8D5511115G
coil spring / for models with heavy duty suspension / 2 paint marks / 2 paint marks
white violet / sedan
(11) 8D9511115D
coil spring / for models with towing facility / 2 paint marks / 3 paint marks
rear white violet / AVANT
(11) 8D9511115D
coil spring / for models with heavy duty suspension / 2 paint marks / 3 paint marks
(11) 8D5511115D
coil spring / for vehicles with sports-type running gear / 1 paint mark / 1 paint mark
white pink /
(11) 8D9511115E
coil spring / for vehicles with sports-type running gear / 1 paint mark / 2 paint marks
white pink / AVANT
12 8D5513029D
shock absorber
rear /
(12) 8D5513029E
shock absorber / for vehicles with sports-type running gear
rear /
(12) 8D9513029A
shock absorber
/ AVANT
(12) 8D0513029
shock absorber / for models with heavy duty suspension / 1 paint mark
blue /
13 N 90563501
hexagon head bolt (combi)
M10X24 /
14 N 0101835
hexagonal head bolt
M12X1,5X75 /
15 N 0211916
hexagon nut, self-locking
M12X1,5 /
16 N 0101867
hexagonal head bolt
M12X1,5X85 /
17 N 10265501
hexagonal head bolt
M12X1,5X212 /
18 N 10270601
hexagonal head bolt
M12X1,5X102 /
19 8A0511341A
washer
42MM /
20 N 10241201
hexagonal head bolt
M12X1,5X85 /
21 8A0501387C
eccentric screw
M12X1,5X95 /
22 8A0501385A
margus
 postitati 30.12.10 12:53
[PHP: 63.5% - SQL: 36.5%]
