Huviliste autod
Huviliste endised autod
Audi A6 Avant 1.9TDI - 2004 - DonNiger (MÜÜDUD)
[quote][i]Algselt postitas: DonNiger[/i] ls 243000 Sai täna jube korra järgi pandud - ABS viskas mingi päev korra tule põlema. Panin ka juhtme taha ja tiirutasin ringi. Veakoodid: 18259 P1851 - Incorrect signal from ABS Control Module Wiring / connections Fault code stored in control module ABS control module incorrectly coded Similar resistance in motor control module 18057 P1649 - Missing Message from ABS Controller Start with the error code to clear and hope he does not come back Check / replace fuse (s) remove the fuse (s) out make the ends of the fuse (s) clean (very light sanding with fine sandpaper, then very little contact spray on it) fuse (s) by measuring with a multimeter (the fuse (s) sometimes looks fine, but appearances can be deceiving) fuse (s) replace / replace Check Wiring / Connections VW Golf and Bora-4. The fuse box on the battery disassemble, clean feet, contacts of the three green pin fuses light sanding and cleaning with contact spray (better yet, place three new fuses). One of these three fuse controls the ABS unit. These contacts do want to corrode and then you get the error described here. The ABS unit is very sensitive to a voltage drop. Poland and the battery terminals clean with a wire brush or sandpaper. After just a lick of grease with petroleum jelly and a good solid mount. 00526 - Brake Light Switch (F) Possible symptoms: MIL = malfunction indicator light Brake lights do not work Cruise control does not Possible causes: Wiring and connections between the Stop lamp switch, brake lights and / or the ABS control module Brake Light Switch (F) failure Brake light (s) defective Fuse (s) making proper contact or are defective Possible solutions: Check wiring and connections Check / replace remlichschakelaar (F) (Check measured value block ABS Control Module) Check (doormeten!) / replace fuses Additional info: More information about the brake light switch. Ross-tech FAQ 2.7. Many Automatic Transmission Control Modules showing error code 00526 or 17087 as a faulty brake light switch would be. [b]You can ignore this error and will not appear when you release the brake pedal before you scan for error codes.[/b] :D 01545 - Sensor for PDC Rear Left (G203) Possible symptoms: Limited operation of the parking Possible causes: Read the question out measuringblock Wire breakage or shorting out the ECU to the sensor (G203) G203 defect Possible solutions: Check wiring and connections from the sensor to the ECU G203 G203 replaced Esimesed 2 ABS kohta, sõidan viimasel ajal üsna harva (jalgrattaga tuleb rohkem kilomeetreid), seepärast kipuvad ka ühendused vist jupsima. Parkimisandurid jetkel jälle töötavad, andur vist tuksis ei ole, küll aga saab niiskus kusagilt ligi. Vihmaga lülitab ennast välja, mõned päevad päikest ja töötab jälle. Õnneks märkasin ühte mahajäetud estakaadi, millel saab seda viga lahkama hakata. [/quote]
Huviliste autod
22
56.1%
43.9%
