Huviliste autod
Huviliste endised autod
Audi A8 3.3TDI Quattro - 2002 - MÜÜDUD!!
[quote][i]Algselt postitas: ahtisaar[/i] Sai siis päeval juhe sappa pandud ning tulemus siis: Address 01: Engine Labels: Redir Fail! Part No: 4D0 907 409 C Component: 3.3l/4VTEDC G400AG D05 Coding: 00016 Shop #: WSC 02314 4 Faults Found: 18062 - Please check DTC Memory of Instrument Cluster P1654 - 35-10 - - Intermittent 17569 - Manifold Temp Sensor (G72) P1161 - 35-10 - Open or Short to Plus - Intermittent 17577 - Mass Air Flow Sensor 2 (G246) P1169 - 35-10 - Short to Plus - Intermittent 17664 - Engine Coolant Temp Sensor (G62) P1256 - 35-10 - Open or Short to Plus - Intermittent Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl Part No: 4D0 820 043 P Component: A8-Klimavollautomat D13 Coding: 00083 Shop #: WSC 02314 3 Faults Found: 00716 - Air recirculation Flap Positioning Motor (V113) 41-00 - Blocked or No Voltage 01317 - Control Module in Instrument Cluster (J285) 79-00 - Please Check Fault Codes 00734 - Potentiometer in Central Vent (G142) 30-00 - Open or Short to Plus Address 11: Engine II Labels: Redir Fail! Part No: 4D0 907 409 D Component: 3.3l/4VTEDC 0000AG D05 Coding: 00016 Shop #: WSC 02314 5 Faults Found: 19472 - Fuel Bypass Valve (N312) P3016 - 35-10 - Open or Short to Ground - Intermittent 16719 - Crankshaft Position Sensor (G28) P0335 - 35-00 - Malfunction 19468 - Relay for Fuel Pump 2 (J49) P3012 - 35-10 - Open or Short to Ground - Intermittent 17645 - Fuel Injector for Cylinder 1 (N30) P1237 - 35-10 - Open Circuit - Intermittent 17687 - Valve for Fuel Metering (N290) P1279 - 35-00 - Open or Short to Ground Address 17: Instruments Labels: 4D0-919-033-MYX.lbl Part No: 4D0 919 033 CL Component: KOMBI+WEGFAHRS.VDO D37 Coding: 00180 Shop #: WSC 00860 2 Faults Found: 01039 - Coolant Temperature Sensor (G2) 30-10 - Open or Short to Plus - Intermittent 00779 - Outside Air Temp Sensor (G17) 30-00 - Open or Short to Plus Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8L0 862 257 Q Component: CV-Pump D17 Coding: 15179 Shop #: WSC 02314 5 Faults Found: 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00991 - Interior Lights 28-00 - Short to Plus 00956 - Key 2 09-00 - Adaptation Limit Surpassed 01134 - Alarm Horn (H12) 49-00 - No Communications Kui kellegil on mõnda head näpunäidet mõne vea kohta oleksin väga tänulik õpetussõnade üle. [/quote]
Huviliste autod
22
47.5%
52.5%
