Huviliste autod
Audi A5 3.0Tdi 176kw S-Line - 2010 - Lauri0112
[quote][i]Algselt postitas: Lauri0112[/i] Tellisin ära veel ka 15mm spacerid ette, pagassi poekoti hoidjad, pidurisadula klambrid ja vahetasin ära ühe parkimis anduri mis aegaajalt viga andis. Seejärel korralik pesu väljast mida veel teinud ei olnud ja see järel mõned pildid. [b]Paneme siia üles ka varustuse nimekirja, mis koodide järgi tõlgitud sai.[/b] LZ7H Audi Meteor Grey E4U = "Sport" 7D5 = DVD player 4UF = Drivers and front passenger air bag with front passenger air bag deactivation 6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated 5SL = Left exterior mirror: aspherical 6TS = Right exterior mirror: aspherical, large viewing field 1KW = Disc brakes, rear J0Z = Battery 520 A (110 Ah) 1LA = Disc brakes, front 1AT = Electronic stabilization program (ESP) 1BV = Sports suspension/shock absorption 3FC = Pop-up sunroof, electrically adjustable 5TG = Decorative aluminum inserts, dulling 7X4 = Park distance control, front and rear F0A = No special purpose vehicle, standard equipment 8GR = Alternator 150 A 0G7 = Tiptronic 0YF = Weight range 6 installation control only, no requirement forecast 0JH = Weight category front axle weight range 8 T41 = 6-cylinder diesel engine 3.0 L unit 059.D 3NZ = Rear seat bench unsplit, backrest split folding 8BP = Bi-functional headlight with gas discharge lamp U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer X0A = National sales program Germany 1N3 = Speed-related variable steering assist (Servotronic) 1XW = Leather trimmed multi-function sports steering wheel 8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1) 9Q4 = Multi-function display/on-board computerwith check control D50 = 6-cyl. turbo dies. eng. 3.0 l/176 kW 24VV6 TDI, common rail Base engine is T41/TE1/TF1/TH1 7T6 = Navigation system (MID) CV6 = Alloy wheels 9J x 20 7K6 = Flat tire indicator 4X3 = Side air bag front with curtain air bag 2K7 = Reinforced bumpers 3L3 = Manual height adjustment for front seats 4KC = Side and rear windows in heat-insulatingglass 4K4 = Radio remote controlled central locking 5D7 = Carrier frequency 868 MHz without panic button 1SA = Without additional front underbody guard 7MG = Emission standard EU5 Q1D = Sports front seats 4GF = Windshield in heat-insulating glass Lisaks on auto küljes ka mingisugune "supplementary heater" mis väidetavalt töötab diisli pealt ja hakkab külma ilmaga salongi kütma kui auto tööle panna. Parandage mind kui eksin, aga sellise info leidsin interneti avarusest ja väga sellesse süvenenud ei ole. [img]https://www.upload.ee/image/15186026/1.jpg[/img] [img]https://www.upload.ee/image/15186025/2.jpg[/img] [img]https://www.upload.ee/image/15186024/3.jpg[/img] [img]https://www.upload.ee/image/15186028/4.jpg[/img] [img]https://www.upload.ee/image/15186029/5.jpg[/img] [img]https://www.upload.ee/image/15186027/6.jpg[/img] [img]https://www.upload.ee/image/15186030/7.jpg[/img] [/quote]
Huviliste autod
44.2%
55.8%
