Huviliste autod
Audi A6 Avant 3.0 165kW Q - 2005 - siim_106
[quote][i]Algselt postitas: vedru[/i] Loe see läbi, eriti viimane lõik; How do I know if the injector I have purchased needs coding? DELPHI Common Rail Injectors – All require coding to the engine. Typical code is 16 alphanumeric characters (C2i Injectors) or 20 characters for more recent applications (C3i injectors). Code typically found on Injector head. DENSO Common Rail Injectors – As a rule, all require coding, although some very early releases may not. Typical code length is 16-24 alphanumeric characters dependent upon vehicle marquee. Code typically found on Injector head. You can also use the QR code found on the injector for this information. VDO/Siemens Common Rail Injectors Injector’s – Only VW applications at this moment require coding. Typical length is 6 digits and found on the injector head. BOSCH Common Rail Injectors – As a rule all require coding, although some earlier releases may not, in simple terms if an IMA code is present then the injector will need coding. Typical length of code is 6-10 digits and found on Injector head. N.B. – The coding information above is related to new diesel Injectors. A remanufactured injector if purchased from an Authorized Field Repairer will also have a new calibration code, which is affixed to the injector as a sticker or label. [/quote]
Huviliste autod
37.4%
62.6%
