 postitati 18.01.19 14:43
Algselt postitas: mkb
http://foorum.audiclub.ee/viewthread.php?tid=181802&fbclid=IwAR2rsPbCTI4SGU8U8CCJ09UUzpcNxUKKfWuxCOpfv02b6iUDDKHAqrykjHI
Algselt postitas: prj
1.8T 120kw/140kw TQ kõige odavam remontida ja pidada.
Edasi 2.0T 147kw, aga kindlasti manuaalkastiga. Automaadiga on neil enamusel üsna raju vibra tühikäigul. /---/
Jah, vibra on küll kohapeal seistes D peal päris ebameeldiv (ka mulle, kes ma diisliga sõidan igapäevaselt), aga foori all seistes N peale ja vibra kaob.
 postitati 18.01.19 10:20
 postitati 18.01.19 09:41
Algselt postitas: stonestick
Just. Aga kuulutuses ikka S-line. Head et "Full Options Black Edition" ei ole :D
Selles osas ma hukka ei mõistaks, kuna tehasest sai tellida ju S-line kolmes komplektsuses (sise, välis ja sise+välis). Sedaenam, et VIN järgi on kirjas: E4J Special editions: "S-line" ja lisaks on ka: 1BV Shock absorption/suspension, chassis: Sports suspension/shock absorption.
Keda huvitab, siis siin kogu list:
Main data
Parameter Value
Brand AUDI
Model AUDI A4 AV. QU. 2.0
VIN WAUZZZ8E95A450942
Check digit Not used
Sales id 8ED0EL
Production date 2005-01-10
Model year 2005
Engine code BGB
Engine volume, L 2.00
Number of cylinders 4
Power, KW 147
Power, PS 200
Colour of body 2Y (BLUE: mauritius blue pearl effect)
Colour of roof 2Y (BLUE: mauritius blue pearl effect)
Trim QE
Gearbox code HHL (6A)
Country of sale 000 ()
Custom options
Parameter Value
1PA Lockable wheel bolts: Standard wheel bolts
0CS Vehicle class differentiation units/platform components: Vehicle class differentiation 8E0
0GG Emissions standard: Emission standard EU4
1D0 Trailer hitch: Without trailer hitch
4UE Airbag: Air bag for driver and front seat passenger
0W1 Label for central electric: Label for central electric German-speaking countries
QE0 Storage compartment package: Without tray areas package/box
6XD Exterior mirror setting: Exterior mirrors: electrically adjustable/heated
5SL Left exterior mirror: Left exterior mirror: aspherical
6TS Right exterior mirror: Right exterior mirror: aspherical, large viewing field
1X1 Drive layout: Four wheel drive
A8S Equipment levels: Standard equipment
1KW Brake type in rear: Disc brakes, rear
J1U Batteries: Battery 450 A (95 Ah)
1LA Brake type, front: Disc brakes, front
6FA Components with special surface appearance: Components without special surface appearance
B0A Component part sets with country-specific design requirements: Component parts set without country-specific design requirement
0VC Owner's manuals: Information kit in German
7QT CD ROM/DVD/SD card: CD ROM (Europe)
7A2 CD changer/CD player: CD changer
C22 General operating permit, alterations: Operating permit, alteration
3S1 Roof rails/roof load rack: Bright roof rails
2T1 Double-size standard radio/dual-view display: Double-sized standard (DIN)
3FR Roof insert/convertible top: Electric sliding/pop-up solar sunroof with automatic pre-selection
3X0 Ski bag: Without load-through provision
2G1 Insert for the filling up of unleaded fuel/fuel type: Insert for the filling up of unleaded fuel
7AA Theft protection system: Electronic vehicle immobilization device
5TG Inserts: Decorative aluminum inserts, dulling
7M8 Scuff plates: Scuff plates in door apertures
7X2 Park distance control: Park distance control, front and rear
0FA Manufacturing sequence differentiation: Standard manufacturing sequence
4R4 Window regulator: Power windows with comfort operation and circuit breaker
5NF Hood and trunk stay: Interstop gas prop for tailgate
8K4 Headlight control: Separate daytime running lights NAR
2V1 Fresh air intake for passenger compartment (with particulate filter): Dust and pollen filter
1C1 Antifreeze: Antifreeze up to -25 degree celsius tolerance up to -30 degree C
F0A Vehicle specifications: No special purpose vehicle, standard equipment
8GU Alternators: Alternator 140 A
0G7 Transmission types/gearshift mechanisms: Tiptronic
1YF Transmission shafts, rear axle: Transmission shafts for rear axle diameter 75.5
1WH Transmission shafts: Transmission shaft w/ 75.5mm in diameter
0YL Weight category rear axle: Weight range 11 installation control only, no requirement forecast
0JJ Weight category front axle: Weight category front axle weight range 9
T61 Base engine: 4-cylinder gasoline engine 2.0 L unit 06D.1
6M0 Tie down straps/net/pocket: Without tie down straps/net/pocket
8T0 Cruise control system: Without cruise control system (CCS)
VC0 Garage door opener: W/o remote-controlled garage door opener
G0R Transmission specifications: 6-speed automatic transmission for four-wheel drive vehicle
6V1 Rear trim panel: Rear trim panel (ECE)
5J0 Rear spoiler: Without rear spoiler
6NQ Molding roof liner: Standard molded headlining
3NZ Rear seats: Rear seat bench unsplit, backrest split folding
9AK Heating and air conditioning system: Climatronic with impact pressure control free of cfc
8ED Headlamps: Bi-functional headlight with gas discharge lamp, for driving on the right
FC1 Customized installation: Customized installation
U2A Instrument clusters: Instrument insert with km/h speedometer, radio-controlled clock, tachometer and trip odometer
4N0 Dashboard: Standard dashboard
4L2 Breakaway interior rearview mirror: Dipping breakaway interior rear view mirror
K8D Body style: Station Wagon Variant/Avant
6SS Luggage compartment floor covering: Luggage compartment floor covering
4W0 Cassette and CD storage unit: Without cassette and CD storage unit
1W0 Refrigerator: Without refrigerator/glove compartment cooling system
1Z2 Fuel quantity for initial filling: Increase in initial standard fuel filling
0F2 Fuel systems: Fuel system for carburetor gasoline engine
5C0 Body measures: Without special body measures
6W5 Front license plate carrier: Front license plate bracket
5K5 Paint preservative/transit coating: Transportschutzfolie (anstelle Lackkonservierung)
QQ0 Light package (lighting): Without add. lights (interior lighting)
L0L Steering system arrangement: Left-hand drive vehicle
1N3 Steering: Speed-related variable steering assist (Servotronic)
7P1 Lumbar support: Power adjustable lumbar support in front seats
1ML Steering wheels: Leather trimmed sports steering wheel
9VD Speaker installation: Speaker (active)
8Q3 Headlight range control: Automatic headlight-range adjustment dynamic (self-adjusting while driving)
6E3 Center armrest: Front center armrest
FM0 Versions: Basic equipment variant
9Q4 Multi-function display/trip computer: Multi-function display/on-board computer with check control
8Z5 Engine cooling system: Not hot country
D2L Engine specifications: 4-Zylinder-Ottomotor 2,0 L/147 KW (16V) Turbo FSI, homogen Grundmotor ist: T59/T61/TQ2/TU2/TD6/TN6
7Q2 Navigation device: Navigation system with color screen
8TF Rear fog lamp: Rear fog lights, left and right
GP1 Upgrading measures: Vehicles with special upgrade measures
4P2 Platform module, luggage compartment floor: Rear floor panel module, type 3
FQ0 Quattro GmbH: Standard production wheels
CL6 Wheels: Leichtmetallräder 7 1/2J x 17 9-Speichen-Design, ET 43
8AY Radios: Radio/navigation system
7K0 Direct tire pressure monitoring system: Without tire pressure warning light
H8A Tires: Tires 235/45 R 17 93Y
V0A Tire suppliers: Tires w/o specification of tire brand
1G8 Spare wheel/breakdown kit: Breakdown set
PNA navigation system plus (RNS-E) withMMI operating logic and navigation DVD
PSV seat heating for front seats
PX4 xenon plus
WQS S line sports package plus (quattro GmbH)
4X3 Side airbag: Side air bag front with curtain air bag
7F9 Gearshift knob/handle: Plastic/leather gearshift knob/handle
A00 Self-collection / special control: No self-collection
2KR Special labels/plates: Labels/plates in English and German
4E0 Lock operation for tailgate/trunk lid: Tailgate/trunk lid unlocking from outside
2K1 Bumper systems: Reinforced bumpers
9P3 Seat belt check: Seat belt reminder, electric contact in buckle
N5D Seat trim covers: Valcona leather seat covering
3L3 Seat adjustment: Manual height adjustment for front seats
4A3 Seat heater: Seat heater for front seats separately controlled
0LW Safety certificate: Special plates/stickers/ safety certificates for Germany
SY1 Control number (no PR family): Control of dummy vehicles
QH0 Audio-response system/voice control: Without voice control
4KC Side and rear windows: Side and rear windows in heat-insulating glass
3Y0 Roll-up sun screen for rear and side windows: Without roll-up sun screen
7B2 Socket: 12-volt socket in luggage boot
FA0 Handling production and pre-production: Control of standard production
8X1 Headlamp washer system: Headlight washer system
4K4 Door and lid locking system: Radio remote controlled central locking
B01 Type approval countries/countries with special requirements: Type approval Germany
5D1 Carrier frequency for radio remote control: Carrier frequency 433.92 MHz-434.42 Mhz
NT0 Transit coating: Transit coating (type 1)
QV0 TV reception/digital radio reception: W/o TV reception/digital radio reception
1VG Installation parts for engine (engine mount system): Installation parts for four-cylinder engine
1SA Front underbody guard: Without additional front underbody guard
1EX Identification plates: Spezielles Typschild fГјr EG
2Z1 Type sign: Type sign at rear and "Quattro" nameplates respectively
1T3 First aid kit / warning triangle: First aid kit with warning triangle
Q1D Front seats: Sports front seats
9W0 Telephone / telematics: W/o car phone preparation/installation
4GF Windshield glass type: Windshield in heat-insulating glass
7FE Additional tires (snow tires): Additional winter tires
0TD Floor mats: Front and rear floor mats
4ZB Decorative trims: Bright moldings
3B0 Additional child seat anchors: Without additional child seat anchor
9M0 Auxiliary heater: Without auxiliary/parking heater
stonestick
 postitati 18.01.19 09:38
Algselt postitas: R-I-X
R-I-Xile täienduseks, et puudub ka S-line nina (etteulatuv lõug ja suurem iluvõre) ja küljeliistud, taguotsas pole kindel. Muidu ilus käru :)
Seal on ainult S-line sise pakett (puudub ju ka luugi tiib, laiad uste liistud, juba mainitud esistange ja tagumine difuuser on ka tavaline, mitte S-line).
EDIT: Tõsi, tegelikult on sisepakett tõesti olemas. Minu vabandused müüjale :P
 postitati 18.01.19 09:36
Aga jah, muidu kena värv ja visuaalselt tundub, et on hoitud.
GeorgJoo
 postitati 18.01.19 09:25
Lihtne numbrimärgi google'dus ja ilmus välja ÕIGE omaniku kuulutus:
http://www.rasketehnika.ee/kasutatud/auto.php?id=3004804&cache_missing=1
:D:D
stonestick
 postitati 18.01.19 09:22
 postitati 18.01.19 09:04
Algselt postitas: Tanel26
https://www.auto24.ee/used/3028352?fbclid=IwAR2EwqeEG0PvAJAPqjvnDxQTPaZRBQdFtsBQjOVP2MHEh2vHRpZP2F5X5y8
jutt käib sellest isendist.
Lihtsalt infoks, et omajagu lisavarustust on juurde mõeldud (nagu autoärikatele kombeks):
* vihmasensor - tavaline salongipeegel, järelikult ei ole (Breakaway interior rearview mirror: Dipping breakaway interior rear view mirror)
* automaatselt tumenevad peeglid (sees, väljas) - kuna puudub isetumenev salongi peegel, siis puudub ka andur ja seega ei saa olla ka välimisi (Breakaway interior rearview mirror: Dipping breakaway interior rear view mirror)
* taskud esiistmete seljatugedes - no ei ole ju
* elektriline antenn - kus?
* esi- ja tagarataste porikummid - no ei ole ju
* sahtlid esiistmete all - Storage compartment package: Without tray areas package/box
* jahutusega kindalaegas - Refrigerator: Without refrigerator/glove compartment cooling system
* rehvirõhu kontrollsüsteem - Direct tire pressure monitoring system: Without tire pressure warning light
* Audi autotelefon - Telephone / telematics: W/o car phone preparation/installation
* ISOFIX lasteistme kinnitus (taga) - Additional child seat anchors: Without additional child seat anchor
* kõrvalistuja turvapadja väljalülitamise võimalus - (tundub samuti jama, sest ESP nupu kõrval ei ole hoiatus lampi, on ainult esimeste park andurite nupp, samuti puudub autos ISOFIX)
Tanel26
 postitati 18.01.19 08:31
mkangur
 postitati 18.01.19 08:27
Kellegil kogemust antud mootoriga Audiga?
2.0 R4 TFSI (147 kW)
automaat (6-käiguline)
Vastupidavus,jõudlus,tüüpvead?
Probleemid: pihustid, kõrgsurve pumba kolb, õlikulu (mitte küll nii suur, kui uuematel 2.0TFSI-del, millel kolvi probleem), sisselaske kinni tahmamine, karterituulutus, käigukasti turbiin, käigukast ise (eriti esiveoliste puhul olev multitronic, mis on täielik õnnetus).
Vaatasin sul profiilis samuti 2.5TDI. Hetkel peres nii 2.0TFSI (B7 atm Quattro ~1a), kui 2.5TDI (B6 man Quattro ~3a) ja siiani on diisel olnud palju muretum.
Palju sul selle multitronicuga kogemust on, et saad väita, et täielik õnnetus? - 0.
Kui hooldad ja on varem korralikult hooldatud siis kestab väga hästi ja kui isegi siduripakk ära läheb kastis, siis noh, tahad väita, et manuaalil ei vaheta sidurit ja hooratast?
Kogemus põhineb kahe multitronicu omamises.
 postitati 18.01.19 07:46
Tanel26
 postitati 18.01.19 07:24
[PHP: 76.6% - SQL: 23.4%]
