S - Audid
S - Audid - üldine
Audi S & RS mudelite andmed ja tutvustus
[quote][i]Algselt postitas: Maku[/i] Car name Audi Sport Quattro Body Typ85 Body form Coupe Modelyears 1984-1985, 1988 Length (mm) 4160 Width (mm) 1780 Height (mm) 1340 Doors 3 Seats 4 Wheelbase (mm) 2224 Unladen weight (kg) 1300 Max weight (kg) 1650 Fuel tank (l) 90 Engine code KW Cylinders 5 Engine type in-line Turbo type Valves 20 Displacement (ccm) 2133 bhp/rpm 306/6700 Torque/rpm 340/3700 Compression ratio 8.00 kg per bhp 4.25 Power density 143 Specials Gearbox Manual Gearbox code AAE Number of gears 5 Steering Servo Brakes front (mm) 295/28 Brakes rear (mm) 295/28 Tires front 235/45 VR15 Tires rear 235/45 VR15 0-100 kmph (s) 4.90 0-200 kmph (s) 23.10 Topspeed (kmph) 248 Air drag Fuel consumption, Average (l/100km) 14.80 City (l/100km) Highway (l/100km) Price (EUR) 104047.90 Units built 214 Allikas: http://rsmodels.net/index.php?mode=cars&car_id=5 Pilte: http://84.50.81.66/gallery/album62 http://www.fourtitude.com/news/publish/Features/printer_1220.shtml Under the Hood: The technology packed into the Sport Quattro was groundbreaking and certainly many years ahead of its time. Keeping weight at a minimum was crucial and as a result the body was constructed from advanced materials including fiberglass, carbon fiber and Kevlar. To keep the driver firmly planted in one place custom Recaro racing seats came as standard equipment. The advanced Quattro all wheel drive system employed a 55/45% front to rear torque split, which could be locked with a switch on the dashboard. Handling the stopping duties was a braking system that featured ABS, discs on all corners and 4-piston calipers. Under the hood lied a 2.1 liter inline-5 cylinder, DOHC 20-valve engine, complete with a lightweight alloy block and cylinder head. Providing the boost was a KKK-K27 turbo, sending 1.2 bar (17 psi) of intercooled air into the combustion chambers. The result was monstrous power levels, 306 horsepower at 6500 rpm, and for competition the engine was easily tunable to over 500 horsepower. Coupled with a curb weight of just 2807 pounds the Sport Quattro reached 60 mph in 4.9 seconds and flat out would hit 155 mph. When you consider this car has the aerodynamic profile of a brick, the performance numbers are even more impressive. http://forzamotorsport.net/news/announcements/sportquattro_overview.htm [/quote]
S - Audid
S - Audid - üldine
22
45.4%
54.6%
