S - Audid
20vT - tuuning
Turbod, boost
[quote][i]Algselt postitas: Maku[/i] [b]K24 (200, S2/4/6) vs K24/7200 (RS2)[/b] [url=http://84.50.81.66/albums/album03/Turbo_comparo.sized.jpg] [img]http://84.50.81.66/albums/album03/Turbo_comparo.thumb.jpg[/img] [/url] [b]K27 (SQ)[/b] [url=http://84.50.81.66/albums/album03/Lader_K27_7.sized.jpg] [img]http://84.50.81.66/albums/album03/Lader_K27_7.thumb.jpg[/img] [/url][url=http://84.50.81.66/albums/album03/lader_K27_7_3.sized.jpg] [img]http://84.50.81.66/albums/album03/lader_K27_7_3.thumb.jpg[/img] [/url][url=http://84.50.81.66/albums/album03/lader_K27_7_4.sized.jpg] [img]http://84.50.81.66/albums/album03/lader_K27_7_4.thumb.jpg[/img] [/url] [b]K24/7000 (200, S2/4/6)[/b] külm väike 42,3 mm külm suur 60,44 mm külma koja nr 5324 101 5084 külm backplate 129,96 mm kuum väike 43,84 mm kuum suur 58,83 mm kuuma koja nr 5326 101 7388 kuum backplate 64,44 mm/74,70 mm [b]K24/7200 (RS2)[/b] turbo nr 5324-970-7200/5324-988-7200 külm pool 48 mm külma koja nr 5326-101-5160 kuum pool 55 mm kuuma koja nr 5326-101-7388 (K24-6.12) [b]K24/7400[/b] külm väike 45 mm külm suur 64 mm külma koja nr 5326 101 5177 külm backplate 128/134 mm kuum väike 49 mm kuum suur 58 mm kuum backplate 64/74 mm [b]K27 (SQ)[/b] külm pool 60 mm kuum pool 63,5 mm http://www.s2forum.com/forum/showthread.php?t=17109&highlight=rs2+turbo+naked&page=5 [i]Here's a list of K26 turbos with the dimensions of the compressor wheels: K26-2664 Urquattro 10V (200 PS) exducer: 66 mm inducer: 42 mm K26-2667 Porsche 944 (220 PS) exducer: 66 mm inducer: 44 mm K26-2670 Porsche 944 (250 PS) exducer: 66 mm inducer: 46 mm K26-2672 GGCAA RS2 (315 PS) exducer: 66 mm inducer: 47mm[/i] http://www.bufkinengineering.com/turbo.htm http://forums.audiworld.com/showthread.php?t=2836186 http://www.924board.org/viewtopic.php?t=15595 [i]K26 #6 turbine wheel - 48mm minor diam, 54mm major diam #6 turbine housing minor bore = 48mm #8 turbine housing minor bore = 55mm Four numbers trailing the "K26" = example, '79 RoW 931 K26-2470 "24" = 2.4" diameter for the compressor exducer (61mm) "70" = compressor inducer is 70% the diameter of the exducer (42.7mm) "R" - still unsure about this... "6.10" refers to the turbine wheel, there's no rhyme or reason with KKK's numbering system here. For example a 5.10 could be larger than a 6.10 which could be larger than a 4.10. Stupid engineers... The KKK part numbers have a little code too- for example: 5326 970 7007 53 (?) 26 (compressor exducer) 970 (?) 70 (compressor inducer percentage of exducer) 07 (the last two digits look like version numbers) [/i] [/quote]
S - Audid
20vT - tuuning
Turbod, boost
22
52.1%
47.9%
