DIY
Püsikiiruse hoidja (Cruise Control) paigaldamine A6 2.5 TDI'le (C4)
[quote][i]Algselt postitas: Petu[/i] Sellega peaksid saama välistada nii mõndagi. To check that the cruise switches are working correctly, look at the patterns of bits on the cruise group in VAG-Com: • Ignition on, engine off. • Engine control module 01 • Read data function 08 • Read group 06 The first block shows the current speed in km/h, 0.0 if you are stationary. Second block shows pedal positions: 0 0 0 no pedals pressed. 0 1 1 brake down 1 0 0 clutch down 1 1 1 both down Third block shows pedals and cruise switches: 000000 - off, no pedals 000011 - on 000111 - Set 001011 - Res 010000 - off, brake pedal down 100000 - off, clutch pedal down [/quote]
DIY
25.5%
74.5%
