Üldine
Kiirendusvõistluste reeglitest
[quote][i]Algselt postitas: Maku[/i] Natuke täpsustavad infot peavoolulüliti kohta. 8.4 MASTER CUTOFF Mandatory when battery is relocated, or as outlined in Class Requirements. An electrical power cutoff switch (one only) must be installed on the rearmost part of each vehicle and be easily accessible from outside the car body. This cutoff switch must be connected to the positive side of the electrical system and must stop all electrical functions including magneto ignition. [b]The external control switch for this cutoff switch will be clearly indicated by a red flash inside a white-edged blue triangle with a base of at least 12 cm (see drawing 25).[/b] The positions must be clearly indicated with the word «OFF». If switch is «push/pull» type, push must be the action for shutting off the electrical system, pull to turn it on. Any rods or cables used to activate the switch must be minimum 1/8-inch (3.2 mm) diameter. Plastic or keyed switches prohibited. Switches and/or controls must be located behind rear wheels on rear engine dragsters. Boldiks tehtud joonis asub [url=http://argent.fia.com/web/fia-public.nsf/3B508127A498C9ABC12573A90051BFA3/$FILE/2009-DessinsDrag%20_10.11.08.pdf]SIIN[/url] - drawing 25. [/quote]
Üldine
35.1%
64.9%
