Audio & navigatsioon
Audi Bose ülevaade & seotud info
[quote][i]Algselt postitas: Maku[/i] [url=https://www.audiworld.com/forums/a8-s8-d4-platform-discussion-190/bang-olufsen-vs-stock-bose-2835957/page8/]Bang & Olufsen vs stock Bose.[/url] [i]I bought the 2013 S6 and didn't go with the B/O, and have been quite disappointed with the Bose system. It is a noticeable step down from my 2004 S4 Bose system, believe it or not. ___________________ I own a Mercedes sl55 that has Hertz speaker, JL amps, JL subs etc and the latest Kenwood receiver. I spent over 6k on this system. I also have a Mercedes GL with all Focal, and JL equipment in it. I just bought a 2011 A8L. It does have the B&O in it. Now when I seen the cost (6300) I said I would never pay for that. However, of course I will take it in a CPO car. My point is that this is the clearest most clearly separated system I have ever heard. With the exception of Bass, this system definitely sounds better than my other two vehicles. I have worked at a high end shop in Center City Philadelphia, and have been involved with many installations. I also had my current two systems installed by a well know South Jersey installer. Just stating this as I am no newbie to high end equipment in vehicles. __________________ For the price of the B&O upgrade the entire Bose system can be replaced with high-end aftermarket gear and yield results that are tremendously better. There is no such thing as a good factory stereo. They simply don't exist. Not at any price point. Your description of the qualities of the B&O system clearly illustrates that you have extensive knowledge and understanding of high-end audio. You would be a perfect candidate for having an aftermarket, sound-quality oriented system. The things you are craving like dynamics, imaging, staging, proper tonality will never be had in a factory stereo system. You need quality components, proper installation and sound dampening to get good results. You also made excellent points about the speaker positions and sound localization. Many car companies market their stereo systems by the number of speakers installed. Having more speakers often makes for inferior imaging and staging, especially when the speaker locations are not laid out correctly and there is not proper processing/equalization. Having a tweeter on the dash inside of a motorized pod, and the matching midrange in the door is a recipe for disaster. A tweeter and midrange should be installed as closely together as possible. Preferably, they should be point source where the tweeter and mid are centered with their voice coils perfectly aligned so they are phase coherent through the full crossover range. If not point source, they must be installed no more than about 7" apart. Time alignment will be required to get the drivers in phase, and that time alignment will only work for a single listening position (i.e. the driver seat). Other listening positions will be adversely affected by the time alignment.[/i] ____________________________ [url=http://www.auto24.ee/used/2046761]Audi S6 Avant 4.0 TFSI V8T 439kW[/url] [i]Autole paigaldatud uus prof. helisüsteem (Rockfrod võimendi, Rockford Punch element originaalkasti sisse ja lisaks sai välja vahetatud ebakvaliteetsed hiina Bose elemendid ustest + tweeterid). Sama protseduuri käigus said paigaldatud ustesse ka mürasummutusmatid. [/i] [/quote]
44.5%
55.5%
